View Full Version : Creaking
fbords
02-26-2005, 06:07 PM
I just got my Goldlines installed this morning. Looks great, but I was wondering does the occasional creaking sound I hear when going over bumps ever go away? I know it's because the coils are touching but I was just curious if it will do that forever.
dgHotLava
02-26-2005, 06:13 PM
could be a few things...
did you put back any seating plates and in the proper position...(they stop squeks and creaks at the ends of the springs...)
did you have any spring wraps to put on...they stop squeks from the spring hitting its self...
is the noise coming from the front or rear???
unlmtdndeavor
02-27-2005, 01:03 AM
is it coming from the front or rear. if it is the rear, usually its because of not putting the rubber wraps on or not having them in the right position
fbords
02-28-2005, 02:55 AM
front right
dgHotLava
02-28-2005, 10:39 AM
front right
its either the end cap bushings, or the spring it not seated right.
Lonely_Raven
02-28-2005, 11:31 AM
I just put my Goldlines on last night, and oddly enough my
front right was also making a squeeking sound that turned into
a clanking sound. Turns out the 17mm nut on the top of
the strut wasn't seated all the way, and the 25 miles I
put on the wheels on springs to seat them loosened it up.
Pop the rubber cap off and tighten both left and right struts
down again.
Make sure you put the two cables back on.
And make sure your lug nuts haven't come loose. Lug nuts
can come loose on aluminum rims really easily in the first
hundred miles or so. Make sure they are torqued to proper
tension.
I'm really enjoying my Goldlines, really nice ride!
fbords
03-01-2005, 01:52 AM
a clanking sound
That seems to be the exact description. I'm not gonna get to that until this weekend. You think it'll hold up?
pdrizzle
03-01-2005, 02:06 AM
It will hold up. I rode with a loose strut for almost 3 weeks. All I had to do was take it off, have a friend hold the cap and compress the coil, and I tightened the bolt down all the way. After you have it on for a week or two, you may want to tighten it down again.
