Tire pressure light on, need help
Old Jul 8, 2010 | 12:50 AM
thisisluiss's Avatar
Default Tire pressure light on, need help
my tire pressure light has been on for the longest time, ive tried reseting it but it wont work. I had the tc rims on and it was still on, put some air on the spare tire as well and nothing, i changed to aftermarket rims and still had the same problem, what can i do? im getting tired of seeing that F*%&ING light on lol
Old Jul 8, 2010 | 12:52 AM
tCtCtC's Avatar
Are you missing your TPMS on your new rims?
Old Jul 8, 2010 | 01:34 AM
krazyliltc's Avatar
^^^^ CHeck that!! Make sure theres a piece of metal around the stem where you put air in your tires. If not then you don't have your TPMS.
Old Jul 8, 2010 | 02:33 AM
MuD3's Avatar
slight thread high jack but related: i wanted to get my rims from a place that ships them with the tires mounted... but i want my TPMS... what to do?
Old Jul 8, 2010 | 03:48 AM
tCtCtC's Avatar
^ Have them shipped to you without the tires mounted and take it to a shop.
Old Jul 8, 2010 | 03:52 AM
MuD3's Avatar
well yes, that is the obvious answer... but i don't wanna T_T
guess i'm going to have to.
Old Jul 8, 2010 | 03:57 AM
tCtCtC's Avatar
Yeah, only option.
Old Jul 8, 2010 | 01:11 PM
dude's Avatar
i was wondering why my light stays on.
Old Jul 16, 2010 | 02:35 AM
allenxtc's Avatar
You can swap your tire pressure sensor in like lesswab or discountire, just bring your stock rims to them. It probably cost 60-90 bucks.. Otherwise, just get used to the tire pressure light on.. =\
Old Jul 16, 2010 | 02:42 AM
Un4Scene's Avatar
From: Living in the Omaha, NE area, traveling all over the continent
It could possibly be a broken sensor or a bad receiver. My mother bought a p.o.s. Suzuki (against my advice) that has the same problem. After she bought a new TPMS for $160 the dealer told her that "for some mysterious reason, the sensors aren't communicating with the receiver".
Personally, I hate the damn things. I can check my own air pressure, thank you very much, and I don't need a computer overcomplicating something for no good reason.
Old Jul 16, 2010 | 11:38 PM
dwn4cause's Avatar
I think if the light stays on for a long time then you need to check the sensors or reciever.
Old Sep 27, 2010 | 02:43 PM
Michele F's Avatar
Default How do I reset the tire pressure light?
I just put air in the tires, but the light won't go out. How do I reset it - not in the manual of course.
Old Sep 27, 2010 | 10:35 PM
SquallLHeart's Avatar
it is in the manual..
Old Sep 28, 2010 | 12:54 PM
headlessmunky's Avatar
make sure all tires are same pressure. Reset IS in the manual, how i reset mine.
Old Sep 28, 2010 | 11:43 PM
RA31925's Avatar
Im having the same issues with the TPS light staying on even though the air is ok. but anyways to answer your question. put air in your tires, check the PSI and open the glove box. on the left hand side you will see a button in side the glove box. hold it down till the light goes off. if the light does not go off then you have a disconnect somewhere between the sensor and reciever. hope that helps
Old Oct 2, 2010 | 01:01 PM
racerx428's Avatar
Try this...Fill tires to proper pressure.... turn key to the on position (engine off) in the glove compartment there is a button (reset) hold that down and it will go off. if you do this with the engine on it will just keep coming back. Hope that helps. Let us know if that works for you.....
Old Oct 2, 2010 | 08:15 PM
Back_In_Black_xA's Avatar
If the computer has lost touch with one of the sensors changing the pressures will do nothing. If this is a chronic problem then it sounds like unfortunately you need to go to the dealer or some kind of shop with the scan tool that can hook up to it and see what is wrong.
Also for the guy who wanted his tires shipped on the rims already you can also have a shop just break the outer bead of the tire and slip the factory tire sensors inside. It's not that big of a deal.
kingofthecrate
Jan 21, 2015 09:28 PM
JDMxB
23
Feb 26, 2004 06:16 AM
Strader
Oct 12, 2003 11:46 PM
