Help me identify a clunking noise? (Dash? Glove box? Strut?)
Old Jul 9, 2010 | 09:44 PM
Jasper Ash's Avatar
Default Help me identify a clunking noise? (Dash? Glove box? Strut?)
SOLVED! See below.
I've searched. I haven't found anything that's been helpful. So maybe, just maybe, someone has been through this issue and knows how to solve it.
I first noticed a loud clunking noise that sounded like it was coming from my passenger side. It has to be because my car is lowered (S-Techs) and its causing extra strain to the body, I thought. I finally got my friend to ride with me and help me determine where the clunk was coming from. He believes its coming from under the passenger dash/glove box. It almost sounds like the windshield or glass roof is rattling or loose. Every little bump and even paint stripes set it off. Here's a short video below that will allow you to hear the noise. It's typically louder, but this is a short video clip. You might want to turn it up a bit.
Any help would be fabtastic.
The 19mm top strut mount bolt was loose. Something I overlooked.
File Type: jpg
Old Jul 9, 2010 | 09:47 PM
yellowxhoodie's Avatar
take your wheel off to make sure that the spring is still seated properly on the strut
Old Jul 9, 2010 | 09:56 PM
tc913's Avatar
how long have you had the springs installed? sounds like a blown strut......cause that's how mine sounded like.
Old Jul 9, 2010 | 10:06 PM
^ could also be the culprit.
and check the 3 nuts on the top hat to make sure they didnt come loose, ive seen that happen quite a few times too.
Old Jul 9, 2010 | 10:11 PM
SR0529's Avatar
where is the video?
Old Jul 9, 2010 | 10:12 PM
click the picture
Old Jul 9, 2010 | 10:40 PM
Aphex13's Avatar
I had the same noise from my driver side. I had to replace my top mount. Part Geeks was the only place I could find one...
Old Jul 9, 2010 | 11:57 PM
SCIONOSIS's Avatar
It's the noisy strut mounts. They're around $60 to $70.
Old Jul 10, 2010 | 12:43 AM
stainless97's Avatar
Make sure all your bolts are tight, but i sounds like a blown strut to me
Old Jul 10, 2010 | 12:53 AM
killatc171's Avatar
i had that same noise, check all your bolts make sure they are all tight, i had a issue with mine when i did my htechs making that same noise and turned out the 2 bolts on the bottom of the strut had worked loose and made that same noise. could also be like the said the 3 bolts up top. or a blown strut.
Old Jul 10, 2010 | 12:58 AM
SCIONOSIS's Avatar
Man, if that clunk sound was in my car, the first thing I would do for diagnosis is to get a 19mm socket, remove the cowl panal to access the strut mounts and tighten that strut tower bolt. Then test drive.
Old Jul 10, 2010 | 02:38 AM
Jasper Ash's Avatar
Thanks to all of you for the replies! I poked around before my initial post and all of the bolts seemed to be okay. I didn't check the top mount or the spring to ensure it is seated correctly. I'll get on that. It's getting worse so I need to do it quickly.
More feedback would be great. If I figure it out I'll update the first post with the answer so people can search this.
Old Jul 10, 2010 | 03:19 AM
Vlad1024's Avatar
Also try the upper strut nut. The one under the dust cover that holds the strut together.
Old Jul 10, 2010 | 03:45 AM
G2Low's Avatar
sounds like the strut itself is loose.. i can take a peek...
Old Jul 10, 2010 | 04:13 AM
Jasper Ash's Avatar
Thanks. I'll check under the dust cover, too.
Anthony, if you can help me with that, it would be pure awesome-tastic. I'm not all that savvy with suspension just yet.
Old Jul 16, 2010 | 05:25 PM
Jasper Ash's Avatar
UPDATE:
At this point I feel confident that its not the suspension. I checked the bolts and the spring and everything seems to be tight and in place. There's no free play anywhere. When I move the front right of the car up and down, I hear no knocking. One of my friends suggested hub-centric rings so I finally picked those up. I really think that something under the dash is loose. Hmmm..
Old Jul 16, 2010 | 06:25 PM
Joyride's Avatar
Dude...im telling you its a cat under your dash playing the drums.
Old Jul 16, 2010 | 11:07 PM
Jasper Ash's Avatar
Or those hamsters. Sneaky little bastards.
Old Jul 16, 2010 | 11:19 PM
dwn4cause's Avatar
Sounds like the strut is lose or blown.. Did you just recently install the strut if so is the spring seated in the right position.
Old Jul 17, 2010 | 12:03 AM
there really nothing under the dash over there besides the heat and a/c components and the pass airbag.
if you realllly think thats it just drop your glovebox and take a look
