Check Engine Light car Die after 4000 rpm
Old Jul 11, 2010 | 09:31 PM
makatc's Avatar
Default Check Engine Light car Die after 4000 rpm
Ok after i clean with water the engine my car die when hit the 4000 rpm
and a check engine light turn on. what can be? thanks
Old Jul 11, 2010 | 10:06 PM
tCjosh's Avatar
does the car have a rough idle? how long did you wet the engine with water???? take it to your local autozone and have them run the diagnostics on the car to see what code its throwing. to me, it sounds like the MAF sensor might have gotten dirty/damaged. you can clean it out with a MAF spray cleaner they sell there too. might want to do that as well. if the MAF is bad after cleaning, then it would need to be replaced and its not that cheap either. hope its something simple and not expensive...GL with fixing your problem...
Old Jul 12, 2010 | 03:48 AM
ESEMRFOZZ13's Avatar
it may be the maf sensor, i believe there is a thread around here.
Jordly221
Feb 13, 2019 05:29 PM
daniinpitt
Apr 4, 2015 08:07 PM
rcflyer15
Dec 5, 2014 05:15 PM
hotroddelux
Dec 3, 2014 11:33 PM
k1114
Nov 30, 2014 01:40 AM
