AEM F/IC Mounting Locations
Old Jul 15, 2010 | 04:34 PM
cavalierkid888's Avatar
Default AEM F/IC Mounting Locations
So where have you guys mounted your f/ic's? or any engine management unit for that matter?
Right now mine is just laying in my glove box with some duct tape over it to keep it from sliding around. Before I taped it whenever it would get jolted/hit the side of the glovebox my car would die if i'm in neutral, and If I'm cruising the car will start to run like poop.
I don't want to just leave it taped in my glovebox, so any ideas guys? Pictures would be great as well.
Old Jul 15, 2010 | 05:05 PM
CarbonXe's Avatar
Two strips of this
http://www.amazon.com/3M-COMMERCIAL-.../dp/B001GXHHW4
and stuck it to the side of the ECU. Easy access, never had a single problem, and the glovebox never got in the way of the wiring.
Old Jul 15, 2010 | 05:19 PM
^^Did you have a wiring harness or did you wire it yourself?
Old Jul 15, 2010 | 05:39 PM
CarbonXe's Avatar
I had the boomsling harness.
Old Jul 15, 2010 | 06:20 PM
Ok thanks, I might just do that then...I've already got a roll of 3M tape....
Old Jul 15, 2010 | 06:33 PM
CarbonXe's Avatar
It takes a bit to get the harness molded into a good position where it won't be crushed by the glovebox, but once it's tucked out of the way, there is a decent amount of clearance.
Old Jul 19, 2010 | 03:38 AM
skinnayyy's Avatar
Team Scionara
i have mine screwed into the glove box. i have the harness and my vac line ran through a hole i drilled out too. at first the box was really hard to close because of the harness but now it's not a problem. makes for easy access for the usb port as well
Zman
Apr 10, 2015 08:04 PM
KILLER
Mar 29, 2015 05:32 PM
mav261
Mar 24, 2015 01:19 AM
mav261
Feb 11, 2015 02:43 AM
