Signal lights not working
Old Jul 17, 2010 | 11:14 PM
mikeo's Avatar
Default Signal lights not working
Hey guys i'm having an issue with my turn signal lights/hazards. Recently my left turn signals stopped working i.e the front, rear and side mirror. I've replaced all the bulbs, the fuses and the flasher relay. They blink once and then stop completely. The right side works fine. Any solutions and info would help!
Old Jul 17, 2010 | 11:38 PM
Un4Scene's Avatar
From: Living in the Omaha, NE area, traveling all over the continent
This sounds like an electrical problem, and I'm more of a mechanical guy but I'll take a guess. Have you checked out the actual switch that the signal stalk moves?
Aside from that... I know it's a pain but you may have to get a voltmeter and find out where in the chain you're losing voltage when you turn them on.
That's all I got on this one. Sorry I can't be more help.
Old Jul 30, 2010 | 11:43 PM
grahamapop's Avatar
Smile
@mikeo I'm so sorry to hear that you're having problems with your turn/hazard lights! Since you have tried changing the bulbs and it hasn’t fixed the problem have you tried contacting your local Scion dealership? If not, they'll probably be able to help you figure out the problem. I hope this helps.
I'm sure you already know, but just in case you can locate your closest Scion dealer by using the following link:
http://www.scion.com/#dealer
Good luck!
-Paul
paul@americanpopdigital.com
I work with Scion, see full disclosure here - http://cmp.ly/4/qrbca1
Old Aug 30, 2010 | 10:31 PM
ScionFred's Avatar
Double check your flasher relay and make sure it's tightly seated. I had the exact same problem and it was caused by the relay coming loose. Pushed the relay in and the left signals worked again. YMMV, good luck.
Old Aug 30, 2010 | 10:35 PM
burstaneurysm's Avatar
in before 'check your blinker fluid'.
xBSciontist
Jun 18, 2019 03:06 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
Opr8r
20
Feb 25, 2004 11:29 PM
