getting a CEL at 30K miles!?
Old Jul 28, 2010 | 12:15 AM
Socalheatz's Avatar
Default getting a CEL at 30K miles!?
is that normal? if so.. how do i turn it off. if not... what's wrong with my car?
Old Jul 28, 2010 | 12:20 AM
DJ08tC's Avatar
hahaha, get the code read, it could be for a bunch of stuff. nobody here can help you if they dont know what the code is for
Old Jul 28, 2010 | 12:21 AM
ack154's Avatar
Of course it's not normal... that's why it's called a "CHECK ENGINE light." You need to check your engine.
And no one is going to be able to help you unless you go get the code read and find out what it is. Try a local Autozone or another auto parts store that will read it. Most do. Once you have the code, we can probably help more.
Old Jul 28, 2010 | 12:27 AM
Socalheatz's Avatar
dang it. i hoping for the "oh yeah when you reach 30K, the CEL will go off, signaling the owner to do some maintenance"
crap, but yeah ill go do that.. now
Old Jul 28, 2010 | 01:43 AM
tedwash's Avatar
Don't forget to let us know what the problem was.
Old Jul 28, 2010 | 03:05 AM
Mouse's Avatar
^^ X2 on that. along with most of the parts stores having an OBDII reader on hand, they can usually look up the code in their system as well.
As for the check engine light... most of the time it does indicate that something needs to be looked at; however, there is one time that will it come on that it does NOT mean there is a problem.... and that is when you reach the 5,000 mark it is indicating that it's time for service (oil/filter change). Then once you change it, just reset the 5K service "counter".
Old Jul 29, 2010 | 07:29 PM
Socalheatz's Avatar
gr my nearest autozone doesn't pull codes anymore, gotta try elsewhere
Old Jul 29, 2010 | 07:37 PM
Jon's Avatar
Jon
Moderator
Moderator
The CEL and the Maint Reqd light are totally different. The CEL is an alert from your ECU while the Maint light is just a dummy indicator that's set off by mileage intervals. Your CEL should not have come on at 5k. In the 82k miles I've driven my car I've never had a CEL.
Old Aug 3, 2010 | 08:18 PM
Socalheatz's Avatar
so i got it checked out pepboys today. and... it was something about the exhaust. code was p0441 i think.. any ideas? oh fyi, i recently installed a raceland catback.. but the code went off before i installed it :/
Old Aug 3, 2010 | 08:28 PM
Spicy_McHaggiz's Avatar
http://www.obd-codes.com/p0441 (I know, google is so hard these days)
Have you gotten gas lately? Make sure to tighten the cap completely.
Old Aug 3, 2010 | 09:11 PM
fewjative's Avatar
The most common CEL problem with the tC is that the gas cap leaks air. Mine was replaced for free by toyota.
Old Aug 3, 2010 | 09:15 PM
tcturbo07's Avatar
^ yep I agree check to see if your gas cap is tight
Old Aug 4, 2010 | 03:39 AM
Socalheatz's Avatar
hm that would explain my dip in MPG lately haha
Old Aug 6, 2010 | 02:03 AM
Socalheatz's Avatar
problem solved? disconnect and reconnected the negative lead, no more cel :D
Old Aug 6, 2010 | 02:14 AM
CleanFMtC's Avatar
My tc was throwing the same code a few months back and i had it cleared, it came back around 75 miles later. So i changed the cap and had it reset and it has not come back since. So if your cap is leaking it will come back on. Got the gas cap for $13 at auto zone.
12xb
Nov 7, 2015 03:44 PM
D_Roke
Mar 31, 2015 05:37 PM
bktply
Mar 17, 2015 04:50 AM
eatcrispycreme2
Jan 30, 2015 03:43 AM
TheTripleC
Jan 4, 2015 06:46 PM
