View Full Version : painting engine cover
rhinonabox 02-28-2005, 04:23 PM I know this has probably been discussed before, but I can not find a thread. 1 simple question. I want to paint my engine cover, but I'm not sure if I need to use Hi heat paint or if I can get away with some regular paint. Hi heat doesn't come in the right colors. Also, if hi heat is required, could I get away with regular paint with a hi heat clear coat?
TheIcon 02-28-2005, 04:46 PM Most people haven't used Hi Heat paint and haven't had trouble. You are safe.
Munch 02-28-2005, 04:48 PM I color matched mine BCP. I used the same paint that is on the outside of the car and no problems at all. Looks like it did the day I did it.
Newtmaker 02-28-2005, 08:42 PM Anyone know if there are aftermarket touchup paint in the spray cans available for the Scion colors? I am looking for TCM.
Walt
rhinonabox 02-28-2005, 09:22 PM ditto.
erichlf 03-01-2005, 10:01 PM I used some engine enamel it worked very well. But, that is for high heat.
disco 03-01-2005, 10:10 PM Goto any paint shop. Purchase some plastic clear spray inhibitor. Wait 30minutes Buy some primer,wait 30 minute prefer gray. Buy your color of choice. Spray every 45minutes or so. After a few hours clear coat it, several coats, alot of coats!!!! Heat paint is not needed. As when your driving the heat is flushed throughout the engine bay. Don't worry about that. Time is key, go slow take your time do not rush this, never rush painting anything on your car. 8 hour max here reinstall and ahhhh color!!!
bB2NER 03-01-2005, 10:11 PM Anyone know if there are aftermarket touchup paint in the spray cans available for the Scion colors? I am looking for TCM.
Walt
I haven't been able to find Scion colors in like duplicolor or such. The best advice would be to find a paint store that puts Scion paint in a spray can. May cost a little more but is alot cheaper than buying a whole quart plus the activator ,reducer plus all the other stuff to spray one piece
LavaBox_v1 03-01-2005, 10:46 PM I had my body shop paint it to match my car using the same paint he used on my car. Its 100% exact color match!
squirrel 03-01-2005, 11:35 PM Make sure you degrease the cover thoroughly, and you may want to scuuf it a bit so the paint has something to adhere to.
Out here in the Bay Area, CA, there are paint shops that sell OEM colors in 20 ounce spray cans for under $20.00. They are great for doing small jobs like eyelids, and engine covers.
What did that cost?
luvmyxb 03-02-2005, 12:46 AM I painted mine with Krylon Fusion paint for plastic. All I did was lightly sand and clean with reducer. No primer. Looks great and has stayed on fine. Mine is bright Red. Cost like $7.95
ThunderGod 03-02-2005, 03:34 AM thanks to SUBZERO'S Sponsor, Sierra Paint and Body. thanks eric!
http://img.photobucket.com/albums/v509/hotxb990/xB990engine.jpg
rhinonabox 03-02-2005, 03:55 AM I found some duplicolor at Wal-Mart that is almost an exact match to TCM. Close enough that you won't be able to see a difference. I'm going to use that and see how it ends up. I also bought some auto clear coat spray. We'll see how it turns out. I'll post pics when I'm done. I put the first coat on tonight.
h82blgl 03-02-2005, 08:40 PM i did my own chk the profile...
rhinonabox 03-02-2005, 08:53 PM i did my own chk the profile...
You work at a body shop? That's a nice job for a diy.
xbox83 03-02-2005, 08:56 PM hey what would you recommend if i wanted to do the vvt-i symbol and toyota symbol a different color. im guessing x-acto knife and some regular ole masking tape but well i wasn't sure and i'd figure i'd ask
-X
rhinonabox 03-02-2005, 09:02 PM hey what would you recommend if i wanted to do the vvt-i symbol and toyota symbol a different color. im guessing x-acto knife and some regular ole masking tape but well i wasn't sure and i'd figure i'd ask
-X
That's my goal. I'm painting the cover TCM and the vvt-i and logo ultra flat black. I'm painting the letters first without masking and then taping over them when dry and painting the rest of the cover. We'll see how that turns out.
DFITE 03-03-2005, 12:23 AM This look nice without all of the trouble....
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7956467528&category=33627
2tone_xB 03-03-2005, 12:34 AM Some dude here in Orlando with a Camo xB did a Camo paint yellow/green/white blend. Came out pretty good for a DIY.
I suck at painting so I just got a CF engine dress up cover.
Good luck.
xtremeOrange 03-03-2005, 12:41 AM www.paintscratch.com for various sizes/quantities of OEM paint :D
Pooka 03-03-2005, 04:46 AM hey what would you recommend if i wanted to do the vvt-i symbol and toyota symbol a different color. im guessing x-acto knife and some regular ole masking tape but well i wasn't sure and i'd figure i'd ask
-X
I think it would be a lot easier to paint the whole thing TCM, and then tape off around the letters... taping over the letters and especially the logo might be more difficult... but taping around them would be fairly easy.
Just my opinion, I've never done painting before... but from what I've seen that would be the way I went.
erichlf 03-03-2005, 04:53 AM hey what would you recommend if i wanted to do the vvt-i symbol and toyota symbol a different color. im guessing x-acto knife and some regular ole masking tape but well i wasn't sure and i'd figure i'd ask
-X
Ijust put some scotch tape over the letters and then used an exacto to cut the excess tape off. Then paint right over that. wait for the paint to dry and peal the tape off. Voila the letters are a different color than the rest.
rhinonabox 03-03-2005, 01:21 PM Believe it or not, I used to spray paint for a living. :rofl:
The best way is to tape off the letters using any low adhesive tape of your choice and an exacto knife. The problem I have found is that you need to hard sand and probably primer before painting. I started with a light sanding and no primer. I ended up peeling off the paint on the letters when removing the tape, and screwed it all up. Now I'm gonna go back to a hard sand and primer then see how the cookie crumbles.
DebDalton 03-03-2005, 05:10 PM I went to the local napa store they matched me right up (Black Cherry) Hi resist. I even have my brake calibers painted to match no prob. They got the color from House of Paint
rhinonabox 03-03-2005, 06:31 PM I went to the local napa store they matched me right up (Black Cherry) Hi resist. I even have my brake calibers painted to match no prob. They got the color from House of Paint
How much $$$? Did they paint it for you or make the paint for you?
DebDalton 03-04-2005, 01:22 AM both Ill have to look at the receipt as I had some other stuff done at the same shop. They pretty cool as I am the only one in town that hasnt left it stock. And there are only about a half dozen other xb s around in town
rhinonabox 03-04-2005, 01:06 PM I had no clue that NAPA did that kind of stuff. So you just drove up to the napa auto parts store and said, I want my engine cover to match my car?
grizzly_choppers 03-04-2005, 03:39 PM I went to the local napa store they matched me right up (Black Cherry) Hi resist. I even have my brake calibers painted to match no prob. They got the color from House of Paint
I'll ditto that. You can't buy touch up in a spray can from Scion. Most NAPA stores can match your color and put it in a spray can for about $10 a can. Bring them your paint code and they should be able to do it.
-Alex
DebDalton 03-04-2005, 05:00 PM yeah napa has a paint caliber(spelling?) machine or like the quy did in my case got the code off my inside door panel. It was sooo easy. Its a high gloss enamel and it looks so good.
firesquare 03-04-2005, 05:36 PM < on their way to napa
Lonely_Raven 03-04-2005, 05:47 PM I'm thinking the same thing about NAPA.
rhinonabox 03-04-2005, 06:03 PM Do they paint it for you? If not, do you primer and clear coat?
erichlf 03-04-2005, 07:38 PM I didn't sand it at all. Just did about 3-4 light coats. Worked great. When I finally clean up my car I will post some pics in my prof.
Was at NAPA this weekend, $16.95/can, min 4 cans.
HotLava1755 03-18-2005, 03:44 AM http://www.etouchup.com/store/agora.cgi
They have what you are looking for
