carbon fiber sticker board
Old Aug 1, 2010 | 04:09 AM
egobuster1's Avatar
Default carbon fiber sticker board
so i got this idea about trying and taking a piece of solid carbon fiber and i want to cut it to basically the shape of the heat shield protector that is on the underside of the hood then i want to do like a collage of stickers and clear coat it and mount it up under there
couple question as i dont think ive seen anyone do this if so please show some pics or it didnt happen
next would it be safe to remove that heat shield or should i just leave it behind the board
also would the heat melt the carbon fiber at all. i think it will be fine as my carbon fiber engine cover is fine
im just brainstorming ideas as im not sure which way to take this
Old Aug 1, 2010 | 05:02 AM
DJ08tC's Avatar
it has been done just not in carbon fiber,
crush02342002 car.
dont know why you would want cf if you are going to put stickers on it
File Type: jpg
Kanchi's Avatar
you would get discoloration where the exhaust manifold/or header (if applicable) is, just like you should (or soon will) be starting to get on the engine cover near the front. If you really want to do this I would make it a show piece and put it in only @ shows. A piece that big would be pretty spendy.
Old Aug 1, 2010 | 05:09 AM
egobuster1's Avatar
well i was gonna leave some spacing to see carbon fiber spots. i dont wanna remove it i want it int here all the time so wat material would your recommend instead of carbon fiber as yes its expensive
Old Aug 1, 2010 | 05:17 AM
robinsondb22's Avatar
if you are just puting stickers on it use a piece of galvanized steel and save some money either way the stickers will get messed up quick if you are driving around with it in there.
Old Aug 1, 2010 | 05:20 AM
Kanchi's Avatar
^this
I would just put the stickers around the edge of the heat shielding or get an air diversion panel and put them there. You will get better looking results but yes it will not be as original.
Old Aug 1, 2010 | 06:18 PM
Murphys_Law's Avatar
stickers should be fine, hot rod guys have been putting their stickers from their parts under the hood for years
Old Aug 2, 2010 | 01:11 AM
egobuster1's Avatar
yeah ive seen people do it many of times just never seen anyone rock it on a tC. ether way once its all done i want to clear coat it really heavy to try and help from the stickers not staying stuck down
Old Aug 3, 2010 | 06:50 AM
egobuster1's Avatar
so wat would be the lightest material that could with stand the heat
Old Aug 3, 2010 | 07:02 AM
captainlaziness's Avatar
I don't see why you couldn't just put the stickers on the underside of the hood itself.
Old Aug 3, 2010 | 12:59 PM
x2 what im saying
Old Aug 4, 2010 | 09:15 PM
egobuster1's Avatar
because first i dont want to remove the fire insualtion that is under the hood and also if i ever wanted to remove it i wouldnt able to with out replacing the hood
Old Aug 4, 2010 | 09:20 PM
Sure you could. Sand paper does wonders.
Old Aug 4, 2010 | 10:04 PM
sand paper/goo gone/wd-40/pb blast/razor blade, all of this will remove stickers
Old Aug 4, 2010 | 10:14 PM
Or, just cover them up by putting the insulation back on...
yupinmytC
22
Jul 27, 2024 07:08 PM
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
prescottn
Sep 13, 2015 09:04 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
