abs vsc trac off no checkengine
Old Aug 13, 2010 | 04:00 PM
civicjerc's Avatar
Default abs vsc trac off no checkengine
changed clutch on my 06 xb now i have all theses light on vsc abs trac off but no check engine. checked all sensor connections. cleaned abs sensors and map sensor. lights still there and i also removed negative cable from battery. nothing changed. the lights do seem to go off when i make a left or right turn. cant figure out need help.
Old Aug 14, 2010 | 03:12 AM
frogbox's Avatar
Did you pull the codes?
You may have damaged the wheel speed sensor wires , your not supposed to let them hang, bend, twist , pull out too far.
but pull the codes , will give you a better idea.
Old Aug 14, 2010 | 06:59 PM
civicjerc's Avatar
Yeah haven't pulled codes because my local autozone said they coulnt
But I do remember abs wire being stretched a little
Old Sep 29, 2010 | 11:45 PM
civicjerc's Avatar
finally fixed it.my axle was broken and so was the wheel bearing. also changed the abs sensor.now it drives great
Old Sep 30, 2010 | 02:44 AM
burstaneurysm's Avatar
Glad you resolved it.
07tcscion
Oct 8, 2015 05:42 PM
kmouse64
Sep 4, 2015 01:11 PM
chabruce
Aug 14, 2015 03:25 PM
Ways808
Aug 2, 2015 08:13 PM
kmouse64
Scion xB 2nd-Gen Wheel & Tire
Jul 22, 2015 10:13 PM
