aem fic basemap for dezod s1 kit?
Old Aug 20, 2010 | 05:28 AM
turbod-tc's Avatar
Default aem fic basemap for dezod s1 kit?
im still noobish on this site and ive never posted a thread but i need help. my laptop crashed and my fic was wiped out some how and i need the base map that was sent with the kit so i can reload it and get it running to the shop so i can get a new tune. if anyone can help me out please do. thanks.
Old Aug 20, 2010 | 05:35 AM
BlckdOutTC's Avatar
how far away is a tune?
Old Aug 20, 2010 | 05:40 AM
turbod-tc's Avatar
about 50-60 miles. its running hella rich and i dont like it all. lol
Old Aug 20, 2010 | 08:19 AM
ScionFred's Avatar
http://www.dezod.com/tech_notes.cfm
Bottom of page.
Old Aug 20, 2010 | 04:54 PM
turbod-tc's Avatar
Originally Posted by ScionFred
oh sweet thanks. will this map work for an 08 tc?
Old Aug 20, 2010 | 05:12 PM
paul_dezod's Avatar
Scionetics
KAD
Email me about it. I need your real name and order ID.
Old Aug 22, 2010 | 06:27 PM
greenbean24's Avatar
if you can give me some info, id be glad to send you the tune on my car right now.
Im sure it wont be perfect, but if your setup is very similar then i know it will get you to the tuner
I actually payed to have the car dynod and street tuned, and this would be the tune
I know it sounds crazy, but i'm just trying to help others out
Old Aug 22, 2010 | 08:42 PM
turbod-tc's Avatar
its the s1 kit and i havnt changed or done anything to it other than exhaust stuff. also ever since i had my last real tune its been shooting misfiring codes. as of now its still showing missfiring codes and running reallly rich. i just need a basemap to safely drive for a week or two. this is the only vehicle i have that my gf can drive around with our new baby in. =[. any help would be much appreciated! thanks.
Old Aug 22, 2010 | 08:47 PM
Have you done the F/IC resistor mod? and what year
Old Aug 22, 2010 | 08:53 PM
turbod-tc's Avatar
im gonna probably say no cause i have no idea what that is. and its an 08. ive been turboed since march of 08. my actual dyno tune was done last summer and ive just been running with what they did and frankly with my old basemap i had for it seemed to work better but like i said my old laptop crashed and i cant get the old basemap. =[. im taking it to a shop the i found from peeps locally that are on here that said they have been to that can actually tune my fic.
Old Aug 22, 2010 | 09:05 PM
alright, 2 things:
1. I have had the exact same problems as you have, and i would say a good majority of turbo guys have too.... you are dealing with "misfires caused by the F/IC".
Its a pretty complicated problem to explain but it has to do with electronic noise and the sensors on the 2az-fe.
I would highly, highly, highly, HIGHLY recommend doing the resistor mod found in this link ( https://www.scionlife.com/forums/sho...d.php?t=154729 ) this was such an issue they made a sticky out of it.
2. give me an email address and i will send you the tune I have, its a mixture of a professional tune, M=Tuned, and Crush's tune. it has worked very well for me on 8psi of boost In order for any tune, even this one to work, you need to do the resistor mod, the car will start better, idle better, run better, and most likely you will lose the misfire codes.
Old Aug 23, 2010 | 03:42 AM
turbod-tc's Avatar
alright, 2 things:
just got off work. yeah after you said resistor mod i looked it up on google and found that link lol. im going to get on that right away! hopefully it will do what it has for everyone else. yeah i just need a map that will let me drive the car daily for a couple weeks til i have enough molah to go get a good dyno tune. its effin 150 an hour on the dyno at the shop where i had it done last year. this other shop is probably gonna be about the same but they know how to use the fic so its worth it. anywho. s8terboywannabe@hotmail.com is my email. thanks gain!
Old Aug 24, 2010 | 01:38 AM
turbod-tc's Avatar
well its up and running. its running alot better with the help of paul. thanks man! now next pay check i should be getting a real tune =]
Old Jan 8, 2011 | 07:58 PM
ProTuner06's Avatar
Exclamation
I also need a base map for my Dezod S1 turbo kit. I'm installing my kit within a week or two and need a base map to get to the tuner that's an hour+ away. I noticed that they have a tune on their page but, I read that tune is for stock injectors which I'll never run my car with boost on stock injectors. Anyone want to email me a Base Map?
I have a Dezod S1 Kit and only supporting mod is an axle-back exhaust.
Old Jan 10, 2011 | 02:52 PM
paul_dezod's Avatar
Scionetics
KAD
If you are the original purchaser, email me your order ID and real name I will email you the base cal.
Old Jan 12, 2011 | 12:01 AM
ProTuner06's Avatar
I didn't buy it as a kit. I bought the S1 Turbo Assembly from you guys and the FI/C used off of here. I couldn't get any good deals on the rest of the parts in the time I wanted so, I decided to just buy the rest of the parts from you. I guess I should have just bought the kit to begin with. :D
Old Jan 12, 2011 | 01:51 PM
paul_dezod's Avatar
Scionetics
KAD
Send me a PM about this.
Old May 13, 2011 | 06:07 AM
Vindiesel075's Avatar
whats the difference between what you send with the kit and the base tune on ur site????
Old May 13, 2011 | 01:36 PM
paul_dezod's Avatar
Scionetics
KAD
The cal on our site for DL was done by AEM on a turbo car with small boost and stock injectors.
Our base cal is done for our kit with larger injectors and a vastly different tune.
Old Jul 20, 2011 | 07:56 PM
elemons's Avatar
i have aem fic 550 and 630 maps i can email to somebody if needed. pm me your email
Hydryman
Feb 23, 2016 03:35 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
brett561tc
Sep 15, 2015 06:33 AM
my06tc
Jun 25, 2015 12:18 AM
