Melting Vacuum Lines
Old Aug 20, 2010 | 10:27 PM
DeAnzaJig's Avatar
Default Melting Vacuum Lines
i recently put a turbo kit on my tc and im having another big problem. my high performance vacuum lines keep getting too hot then flattening!!!! im trying to keep the heat down, so i heat wrapped the manifold, downpipe, and wastegate dump. still no luck. the lines arent even close to the turbo. i bought lines on ebay, the only thing i bought cheap and is the only thing failing! so im wondering what are some good vacuum lines that can withstand a good amount of heat??
Old Aug 20, 2010 | 10:30 PM
deathbyc4's Avatar
http://www.designengineering.com/cat...ose-protection
they sell this stuff at Advance auto parts
Old Aug 20, 2010 | 11:26 PM
trd07tc's Avatar
go get 3/16" heater hose at advance auto parts
stop using the phrase "high performance"
Old Aug 21, 2010 | 02:15 AM
OuterHeaven's Avatar
These sound like they are failing due to the vacuum. I have used cheap line before but quickly upgraded to fuel line which works great.
Old Aug 21, 2010 | 02:21 AM
m6ar2cel6oTC's Avatar
This!!! Lol can I see what's so high performance? Lol
Old Aug 21, 2010 | 02:25 AM
SoFloTC's Avatar
ive never had this problem
Old Aug 21, 2010 | 03:38 AM
speedy000's Avatar
silicone hoses= fail!
the vac lines they sell at any local auto store/ hardware store work perfect!
Old Aug 21, 2010 | 05:30 AM
DeAnzaJig's Avatar
well i was just sayin high performance cuz thats what they were called! and thanks for the input
Old Aug 23, 2010 | 04:33 PM
BlackKnight's Avatar
Music City Scions
Are you running engine management now? If not I'm sure this could be the cause of it, how high are you're EGT's?
Old Aug 25, 2010 | 03:29 AM
BlckdOutTC's Avatar
mount the vac block outside the engine bay
Old Aug 25, 2010 | 11:11 AM
Where in the trunk!? Lol. Just reroute the hoses better that they don't touch whatever is melting the hoses.
Sent from my iPhone using Tapatalk
Old Aug 25, 2010 | 02:56 PM
BlckdOutTC's Avatar
glove box, under the glove box, etc. did it for this exact reason so ish dont melt
Old Aug 25, 2010 | 03:02 PM
The longer the vacuum hoses the less accurate they are. Or so i heard.
Old Aug 25, 2010 | 03:12 PM
BlckdOutTC's Avatar
under the glove box there's a panel that pops off. my fic is mounted to the outside of that(facing the ground). and the vac block on the reverse side (hides when you attach the panel).
my wastegate is to the turbo, and the blow off is t'd off up by the throttle body. so the ac block is used for boost gauge and fic at the moment
SloTC1
Aug 16, 2018 02:45 PM
gqdabien
Oct 8, 2015 05:36 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
edwinisdumb15
Regional - Pacific South
Sep 18, 2015 10:48 PM
gottoaster
Sep 6, 2015 07:17 PM
