Exhaust Rattle
Old Aug 23, 2010 | 09:43 PM
fury575's Avatar
Default Exhaust Rattle
I got my ptuning 3" exhaust installed but while driving every little bump I hit it sounds like it is just bouncing around on the cross member. Does anyone else have this problem and is there anything to do to fix it?
Old Aug 23, 2010 | 10:40 PM
trd07tc's Avatar
call ptuning?
Old Aug 23, 2010 | 11:08 PM
Frizz's Avatar
Team ScionTific
I have a mid pipe that did that. A hammer worked great!
Old Aug 23, 2010 | 11:10 PM
ack154's Avatar
Have you gotten under it yet to see exactly what is happening? Otherwise it's just speculation on what is the actual problem.
Old Aug 24, 2010 | 01:22 AM
fury575's Avatar
Well ya, I saw that it is just a couple inches from the cross member and I cant look at it while its driving for obvious reasons so I would assume thats what the problem is.
Old Aug 24, 2010 | 01:24 AM
fury575's Avatar
I was thinking about just heat wrap around the cross member so it not so loud and it should be fine, Its seems to be the fitment issue from running the adapter from the Turbo toyotas 2.5" s-pipe to the ptuning 3".
Old Aug 24, 2010 | 03:28 AM
myr6goesfast's Avatar
push the midpipe up and down to see where EXACTLY it's hitting. My Dezod was hitting on a heatshield bolt. I bent the hangers a bit (the ones nearest to the spipe)
Old Aug 24, 2010 | 08:20 PM
MrC_Ptuning's Avatar
Your exhaust should not be rattling or hitting any part of your car. There's a cross-bar that sits underneath the center of the car under the exhaust tunnel. This black cross-bar needs to be removed (2 bolts) since it does not allow enough clearance for the 3" exhaust tubing.
Here's how the ptuning 3" exhaust should look like after installation.
If you're still unsure, give us a call at 1.877.PTUNING
MrC
Old Aug 24, 2010 | 08:42 PM
Carlos@Ptuning.com's Avatar
What Mr.C said, there is no hammering, or bending required. Double check the install or give us a call to help out.
Old Aug 30, 2010 | 07:47 PM
fury575's Avatar
Removing the cross-bar seemed to be the answer. No noise since.
njb411
May 18, 2015 02:28 AM
Savidi
May 2, 2015 11:40 PM
alexxfender
Apr 1, 2015 03:06 PM
StatuSCheckA
Scion tC 2G ICE & Interior
Dec 4, 2014 03:15 PM
sithscripter
13
Feb 1, 2004 03:35 AM
