Katrider2005
08-28-2010, 01:56 AM
My 2006 xA did not come with cruise control. Is it easy to add on now or is it not recommended?
View Full Version : Cruise Control Katrider2005 08-28-2010, 01:56 AM My 2006 xA did not come with cruise control. Is it easy to add on now or is it not recommended? draxcaliber 08-28-2010, 02:06 AM just go to www.trdsparks.com and order it. have your dealership install it. BTW, none of them did, it is an add-on. toxshox 08-28-2010, 04:04 AM I agree. I had one installed and it works just fine. Only issue I had was the custom shop that did the work didn't tighten a bolt tight enough so I had a little rattling under the hood. I tightened it and all is good. Make sure they place the cruise control knob high enough on the column so it doesn't get in your way when you drive. I guess that is more important if you use your left leg on a clutch all day. :wink: |
