2004 xB Rotors stuck like chuck
Hey guys, I was doing a brake job for my buddy who has a 2004 Scion xB, got the caliper and pads done no problem. The problem is that the rotors will not budge. I checked out the write-up (helped alot BTW), it says you do not need to remove the big nut on the end of the axle, is that correct? I've tried beating the rotor with a rubber mallet, with a regular hammer hitting between the lug studs, PB Blaster etc. Am I missing something very simple here? How the hell can I get these rotors off?!
If I remember the 2 holes between the studs are threaded so you can push them of with a couple of bolts check this DIY and pic below, cant remember what size. Beating the F out of it can damage your wheel bearings
http://www.clubxb.com/forums/f18/diy...kes-31253.html
So what do I do to get it off if I don't have a bigger hammer? I'm going to try again tomorrow, I guess for now I'll pick up another bottle of PB Blaster and spray the hell out of it. Would heating it up with a propane torch help it or would I be running an unnecessary risk of burning/breaking something?
maybe, but I did do new pads (napa ceramic pads) on mine today, and those holes were threaded, looked like just a standard 10mm to me, if I had been doing rotors on mine I wouldn't have had a problem, they both fell off when I took off the calipers
I know for a fact that I had the Toyo factory rotors on the car that came with it in 2005 when I drove it home... the only mainteance that Toyo has ever done were my first three oil changes, when I got my clutch safety switch replaced (under warranty) and an oil change at Toyo of Des Moines... thats it...
I just did my rotors 2 months ago, my right front was just like yours, stuck. I had to beat the hell out of it to get it off. It eventually came off, threw on the new rotors and pads. A small hammer wont work, a larger mallet would be better a small chunk of 2x4 and a regular hammer should also suffice. Hang in there and don't let it beat you
