power steering delete
Old Sep 13, 2010 | 12:12 AM
kradstct's Avatar
Default power steering delete
i was wondering what manual pack and pinion setup would work on the tc instead of are power steering one and no i not doing this to gain horsepower and this is on my track tc that will never see a street agian i am doing this cuz i like the feeling of been able to feel the car turn so any help would be good
Old Sep 13, 2010 | 09:53 PM
rivas_203's Avatar
you could just de-power the stock rack. i did this to my other car. basically you open up the rack, remove the rubber seals, all the residual fluid, grease it up and put it together again. then again i did this on a '91 car, not sure if our racks would be as simple
Old Sep 13, 2010 | 10:17 PM
mileoutrage's Avatar
I would assume you could just take the fuse out and it would deactivate the system. It is after all a EPS
Old Sep 14, 2010 | 03:30 AM
sciontc_mich's Avatar
when did the tC become electric steering? It's hydraulic on the 05,06, 07s.. haven't seen the 09's myself. Doubt they changed it.
Old Sep 14, 2010 | 11:26 PM
damn i fast forwarded to 2010, my bad.
In for the answer now though.. Where exactly is the pulley and pump? What is belt size with out it?
Is it possible to loop the line?
Old Sep 15, 2010 | 10:04 AM
kradstct's Avatar
the pump and pulley is in the back and the bolt to relaese the pressure of the belt is in the way of the belt to reroute it and im not sure the belt size yet and mine ould be shorter cuz i dont have the ac already
Old Sep 15, 2010 | 12:29 PM
I'm going to attempt to get back there and see if there is any way to loop the lines so that some fluid remains in the rack to keep things lubricated, on one of my old cars I made a breather system and it worked fine, but like the post above, taking out the rack completely and just greasing it up would work just as good, the problem you are really looking at is premature wear from no fluid in there.. only question is how hard is that going to be...
Old Sep 15, 2010 | 08:59 PM
After doing some research, I am not wanting to loop the lines but rather take the whole system out, so has anyone had experience with actually taking out our rack itself? I want to do this and grease it up every now and then..
Also need belt size for running without PS, what is the easiest way to go about this?
Old Sep 16, 2010 | 03:54 AM
Blue_TC_Man's Avatar
uhh taking out rack out will be a _____ with the sub-frame, id just leave in the power steering honestly. No matter how much grease you put in a power rack it will always have more resistance than a manual rack. Your going to feel the rack more without the power steering that you would with it. Your better off just keeping it as it is
Old Sep 16, 2010 | 02:38 PM
Do you think looping the line back in to itsself and adding a breather would help? I mean that keeps fluid in the rack.
He is a link so what some other people do.
http://www.sr20forum.com/technical-i...-steering.html
http://www.preludepower.com/forums/s...46880&posted=1
^ that one is without the breather system
http://www.civicforums.com/forums/11...-steering.html
newer civic
I know our car is completely different but the concept remains the same to keep fluid in the rack. From what I have read its not much different then actually have a PS pump and pulley.
Old Sep 16, 2010 | 07:46 PM
rivas_203's Avatar
yeah this is pretty much true. you can depower, loop the lines around, whatever, it still wont be as easy as a manual rack, but you will have a better steering ratio.
Old Sep 16, 2010 | 09:52 PM
trd07tc's Avatar
if you get rid of the power steering pump you need to fabricate an idler pulley in its place.
im running without AC/PS
Old Sep 16, 2010 | 10:48 PM
What is the need for the idler pulley? Could you not just get a smaller belt size?
Old Sep 17, 2010 | 02:30 AM
i think you cant route it right without the p/s pulley,
but yeah you could loop the lines and it will help, but again what feel you gain in de-powering the rack you will get back in the added resistance of the rack fighting you
Old Sep 17, 2010 | 02:41 AM
weezyfbayba's Avatar
honestly is it worth it? whhat do you gain from doing this? it's not a civic if you wanted a civic you should have gotten one not a tc
Old Sep 17, 2010 | 01:54 PM
I just want to get rid of anything unnecessary for track events, but this sounds like too much of a _____ to worry about as of right now.
It would be nice to get rid of all that weight up in front of the car and get steering feedback while doing it.
Old Sep 18, 2010 | 02:03 AM
Spicy_McHaggiz's Avatar
If you're drag racing the car, you would see a very SLIGHT benefit by removing the power steering. However if you do any other racing, you would actually hurt the performance of the car. Especially if you simply disconnect the power steering and leave the rack, it would make it near impossible to turn without a lot of force. Even upgrading to a manual rack would be a waste since you'd still need a lot of effort to turn the vehicle. And for the fact, 95% of race cars use power steering.
Old Sep 19, 2010 | 11:02 AM
kradstct's Avatar
what kind of rack are you runing on the car
Old Sep 21, 2010 | 02:00 AM
trd07tc's Avatar
OEM
got fittings for the rack to loop a line with PS fluid
you need to make either a bracket for a pulley where the PS pulley used to be or make a new tensioner. You cannot route a belt without a pulley in the PS spot while using the OEM tensioner
icestorm
Jun 25, 2015 05:44 PM
Zipo
Apr 13, 2015 03:31 PM
allaboutdabox
Mar 17, 2015 07:22 PM
