Scion xB 2nd-Gen Forced Induction Turbo and supercharger applications...
Fred's Ghetto Ebay Catch Can
Old Sep 15, 2010 | 07:08 AM
ScionFred's Avatar
Default Fred's Ghetto Ebay Catch Can
I could have just bought a good Saikou Michi PCV catch can for $110 but what fun is that? Instead I wasted some time searching ebay for a Greddy/Megan knock-off with 15mm fittings. As expected with ebay I received a catch can with 9mm fittings instead. I searched Home Depot for some 1/2" or 5/8" fittings but they only had the same 3/8" that came with the can. Now I could have done what many do and simply reduced my PCV hose from 5/8 to 3/8" and had a marginally effective catch can that restricts PCV air flow but I don't roll like that. Instead this is what I did:
I had to use a rotary tool and carbide cutting bit to enlarge the holes slightly to fit 1/2 copper pipe.
Scotch Brite pads and SS scouring pads from Walmart, under $5 for enough to make 3 catch cans like this.
Leftover 1/2" copper pipe, 45* fitting, solder, flux and a MAPP gas torch were required. I already had all this.
Scotch Brite layer to separate bottom chamber from top.
Finished catch can waiting for sensor-safe RTV and 2-part epoxy to cure before bracket fabrication and installation. Since I already had all the parts and tools except for the scotch pads and SS pads, the total cost was under $30. It should work very well and I can easily replace the filter media whenever necessary. The 5/8" PCV hoses fit snugly and will cover the copper pipes, the epoxy dries clear and I'll trim the excess RTV. It was a fun little project.
Comments, questions, suggestions or criticisms welcomed.
Old Sep 15, 2010 | 08:38 PM
45SSxb2's Avatar
what does it do?,,lol and how do you change the filter ..do you have to take the epoxy off to do so?
Old Sep 15, 2010 | 08:51 PM
buickid's Avatar
https://www.scionlife.com/forums/scion-xa-xb-1st-gen-drivetrain-power-1638/what-does-oil-catch-can-do-57707/
Old Sep 16, 2010 | 03:44 AM
ScionFred's Avatar
An oil catch can serves to separate and trap oil residue present in the blow-by gasses in the PCV system and reduce the amount of oil that is sent through the intake system and back through the combustion process. At idle and low speeds the PCV blow-by gasses are drawn through the PCV valve and into the intake manifold by vacuum. Fresh air is drawn from the intake tract (breather side). At higher rpm, when blow-by volume is highest, the direction of flow reverses and the gasses are sent back to the breather side, through the TB and intake manifold. This isn't really a problem for normally aspirated street cars but it's more important for forced induction engines.
With FI pressure in the intake manifold closes the PCV valve sending all blow-by gasses towards the breather side where over time the oil coats the pipes, intercooler, turbo and TB. Oil also lowers the octane rating of the air/fuel charge. Some people run catch cans on both sides of the PCV system but the more important side is the breather side, which is where I'm installing my CC.
The epoxy is only on the pipes and cap. It can still be taken apart by removing 4 screws.
Old Sep 16, 2010 | 03:48 AM
ScionFred's Avatar
I saw a little good info there, a lot of misinformation and some really bad ideas.
Old Sep 16, 2010 | 07:17 PM
45SSxb2's Avatar
thanks fred for clarifying that info and puttin it all in one spot.... how the catch workin so far ?
Old Sep 17, 2010 | 04:40 AM
ScionFred's Avatar
I can't say, I haven't had time to fab a mounting bracket and install it yet.
Old Sep 21, 2010 | 12:49 AM
TrevorS's Avatar
Super cool, Fred -- you have a way with mods !
Old Sep 21, 2010 | 02:16 AM
ScionFred's Avatar
Thanks Trevor. I wish I could take full credit but I got most of the ideas from the www. I do like the my idea of placing a barrier layer of scotch brite material between the SS wool and the inlet/outlet. If the SS wool ever comes apart it won't be sucked through the engine.
Here are the installed pics:
Mounting bracket made from Home Depot AL bar stock
5/8" EPDM heater hose for now until I can find some nitrile rubber hose in 5/8" ID. EPDM has low oil resistance.
Old Sep 22, 2010 | 05:02 AM
gwtc's Avatar
Very nice...props to you on this one.....
Old Sep 22, 2010 | 05:14 AM
ScionFred's Avatar
Thanks.
Old Sep 22, 2010 | 01:10 PM
XD40tC's Avatar
When I made my eBay catch can for another car a while back I used one of them fluffy shower thingies. Just cut some off and stuffed it in there. Worked very well lol
Old Sep 23, 2010 | 04:03 AM
ScionFred's Avatar
That's a great idea! How did it hold up to the PCV gasses and oil?
Old Sep 27, 2010 | 06:52 AM
XD40tC's Avatar
Very well! Didnt seem to degrade or melt or anything
Old Sep 27, 2010 | 05:47 PM
ScionFred's Avatar
Cool. I might try this when I change out the existing filter media.
Old Oct 7, 2010 | 01:50 AM
gwtc's Avatar
Hey...so whats holding the copper tubes in place? thanks.....
Old Oct 7, 2010 | 02:53 AM
ScionFred's Avatar
Some leftover 2-part epoxy I had laying around. 3M brand IIRC.
Old Oct 8, 2010 | 12:53 AM
gwtc's Avatar
Gotcha....I'm going to try to modify my NRG one like yours, thanks again for sharing......
Old Oct 8, 2010 | 04:25 AM
ScionFred's Avatar
Cool, good luck with it. FWIW, I got sloppy with the epoxy so I'm very glad I used clear.
Old Oct 9, 2010 | 07:18 PM
papo's Avatar
should of painted it black, and that is not a ghetto catch can...
