07 TC oxygen sensor
Old Sep 18, 2010 | 12:49 AM
g0t0pless's Avatar
Question 07 TC oxygen sensor
I just bought a narrow band AFR gauge that needs a 0-1v sensor.
Does my TC use a 0-1 or 0-5 sensor? If it is a 0-1, what wire on the ECM would I get the signal from?
A wideband gauge is out of my budget.
Old Sep 18, 2010 | 01:17 AM
1AZ's Avatar
1AZ
well sorry to say but you pretty much just waisted your money because that gauge will do you no good you need a wideband
Old Sep 18, 2010 | 05:26 AM
bdyer666's Avatar
its like 0-3.2 or 4 it is a wraf 02 and you cant use that gauge with it
Old Sep 18, 2010 | 07:18 AM
g0t0pless's Avatar
I am aware of the wideband being more accurate than the narrowband. Thanks for the tip.
Back to the original question.
Since I can't use the existing O2 sensor (thanks for the helpful info bdyer), where would be the best place to mount an auxiliary O2 sensor that is compatible with the gauge? I would assume it needs to go BEFORE the catalytic convertor.
Old Sep 18, 2010 | 04:36 PM
1AZ's Avatar
1AZ
the s pipe will be a good spot near the downstream one
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
prescottn
Sep 22, 2015 01:30 PM
gqdabien
Sep 17, 2015 09:23 PM
Topfueltom69
Sep 6, 2015 05:25 PM
