ABS and TRAC OFF lights Only
Music City Scions
I decided to throw the stock air cleaner assm. and muffler back on. Then all the sudden only these two lights come on after the first few miles. Seems using the brakes triggers the lights. I cleaned the MAF sensor and checked all the ABS sensor plugs and can't figure out why they keep coming on. I'm about ready to just put black tape over the lights. It runs and brakes normal so I'm stumped???
Please help?
Please help?
Music City Scions
I checked everything around the muffler and airbox. Everything is still connected.
It still stops on a dime when performing a panic stop.
Maybe the system is relearning how to run with the stock parts? Hopefully it's not having issues with running stock muffler and a 4 into 1 header. It was fine with the Strup exhaust and Injen SRI.
Music City Scions
Yep, I watch them come on sometimes as I apply the brakes. I'm beginning to think the LED tails are causing it but why all the sudden after 2 or more years with the LED tails?
Music City Scions
FTHOI I went and re cleaned the MAF sensor, disconnected the battery overnight and threw it on the battery tender. This morning I took it into town and the lights seem to be off for good. It's weird but these things all worked???
Thanks for the help and I'll report back if they return.
I have the LED tails with no problems for 2 years now. So I decide to upgrade the stock third brake light to the LED one Oznium sells, and right away it through the lights. The thing started to drive real bad, with the tranny hunting for the right gear. Put the stock third brake light back in and no more lights.
Very odd. The ABS, VSC system must have something to do with that third brake light or a combination of the three. And by changing one or another to LED, the warning lights come on.
Music City Scions
Now I'm not so sure about that statement.
Not sure if adding a resistor to the mix might trick it into thinking you have a standard bulb in there.
Yeah, like I said, I have LED tails with no problems. It's just when I added that third light that I bought right after reading the Tomas thread about adding the flasher.
This one:
https://www.scionlife.com/forums/sho...d.php?t=146923
I tried doing a search on it and came up dead. You'd think after all this time someone might have the answers !!
This one:
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
umnitza
Dec 1, 2014 06:26 PM
