where to find carbon fiber valve cover?
Old Sep 28, 2010 | 06:40 AM
LtBradleykins's Avatar
Default where to find carbon fiber valve cover?
does anyone know where to get the carbon fiber valve cover with the VVT-i insignia on it?
Old Sep 28, 2010 | 04:29 PM
1AZ's Avatar
1AZ
step one go to ebay
step two type in scion tc/ or xb carbon fiber engine cover
step three look at all 300 and youll find the one you want
Old Sep 28, 2010 | 04:45 PM
Olesen_Custom_Automotive's Avatar
Scion Dynasty
^^ followed those steps, i'l make it easier and post the link
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Old Sep 28, 2010 | 06:13 PM
nrgwar's Avatar
Originally Posted by 1AZ
step one go to ebay
But ones that have VVT-i on them?
Nothing is listed in that link with what the person is asking for ;)
Old Sep 28, 2010 | 08:59 PM
Alvie's Avatar
^^ 3rd one from the bottom
http://cgi.ebay.com/ebaymotors/Toyot...s#ht_500wt_956
Old Sep 28, 2010 | 10:11 PM
Pasquale's Avatar
If you want to be legit....
http://passwordjdm.com/category.aspx...ID=1343&Page=2
....Then proceed to be legit LOL
Dry Carbon, Gel, and Kevlar =D
Old Sep 28, 2010 | 10:39 PM
buickid's Avatar
VVT-i isn't much to get excited about anyway. VVTL-i, now thats the good stuff.
Old Sep 29, 2010 | 01:21 PM
Scion Dynasty
scroll down the page in ebay....out of the whole page, about 4 or 5 are the vvti
Old Sep 30, 2010 | 02:47 AM
OKay... so what is VVTL-i? Or rather... what does the "L" stand for, I take it that VVT stands for Variable Valve Timing? and thank you all for all the help looking for the valve cover.
Old Sep 30, 2010 | 12:34 PM
Scion Dynasty
vvtl-i is toyotas version of VTEC.
copied from wikipedia:
VVTL-i (Variable Valve Timing and Lift intelligent system) is a version that can alter valve lift (and duration) as well as valve timing. In the case of the 16 valve 2ZZ-GE, the engine has 2 camshafts, one operating intake valves and one operating exhaust valves. Each camshaft has two lobes per cylinder, one low rpm lobe and one high rpm, high lift, long duration lobe. Each cylinder has two intake valves and two exhaust valves. Each set of two valves are controlled by one rocker arm, which is operated by the camshaft. Each rocker arm has a slipper follower mounted to the rocker arm with a spring, allowing the slipper follower to move up and down with the high lobe without affecting the rocker arm. When the engine is operating below 6000-7000 rpm (dependent on year, car, and ECU installed), the low lobe is operating the rocker arm and thus the valves. When the engine is operating above the lift engagement point, the ECU activates an oil pressure switch which pushes a sliding pin under the slipper follower on each rocker arm. This in effect, switches to the high lobe causing high lift and longer duration.
Toyota VVTL-i
DebbieS
Jan 27, 2015 06:27 AM
mischman
Jan 14, 2015 06:07 PM
ExtremeDimensions
Dec 18, 2014 04:47 PM
umnitza
Dec 1, 2014 06:26 PM
2fixA
33
Jul 30, 2004 03:13 AM
