View Full Version : front differential oil?
shangtsung
03-04-2005, 05:12 AM
What is the front differential oil that needs to be replaced in addition to the manual transmission oil?
IBJanky
03-04-2005, 08:30 PM
i wasnt aware than scions had a "front differential" :P
shangtsung
03-05-2005, 05:47 AM
Page 7 of the scheduled maintenance guide, at 30k miles:
Replace front differential oil
Replace manual transmission oil
Tighten nuts and bolts on chassis
crayonBOX
03-05-2005, 06:46 AM
that's just like "tighten nuts and bolts on chassis"...
there are no `real` nuts and bolts they need to tighten... millions of cars go without that kind of care...
shangtsung
03-05-2005, 07:02 AM
millions of cars don't have that listed in their maintenance guide either....
Derk-xB
03-05-2005, 01:16 PM
That's a poor argument...
Shang - what's your question? Are you asking what kind of oil to use? Are you asking what the oil is?
The manual will tell you the range the oil should be (75w-90 or something). The oil is essentially your transmission oil.
shangtsung
03-19-2005, 09:11 PM
It's listed as a separate item but I only found one drain plug and one fill plug on the transmission case.
boilerman
03-19-2005, 10:10 PM
Might check the lug nuts. I once had a rattle develop in the front left of a nearly new Ford Ranger. One of the lug nuts had backed off completely. I had a truck deposit a rim and tire in my yard as he passed one time. A very shook up felow.
chadfo
03-19-2005, 10:21 PM
Does anyone know the capacity of the transmission. I want to change mine and don't know how much fluid to buy.
jct
03-19-2005, 10:24 PM
thats an easy one just keep filling it up untill oil starts coming out of the fill hole, welllllllllll if the fill hole is on the side that is
Derk-xB
03-19-2005, 11:37 PM
Tranny fluid should be bathing your differential as well.
Capacities should be in the manual, right? Fill-to-spill is a good rule of thumb, just make sure the car is level. :wink:
Rion
03-28-2005, 07:44 AM
It's a front wheel drive car.
We have transaxles, which means that, with the manual at least, the differential and transmission are in the same case, it's like one piece. Differentials and manual transmissions both use gear oil. You can find it at any auto supply store.
bB384
03-28-2005, 08:52 AM
Actually I was planning on doing this sometime this week so I might as well ask now...What viscosity should we use? whats the capicity? And where is the fill plug?...on the Manual tranny of course. Thanks in advance!
