Stick Shift.
Old Mar 4, 2005 | 06:48 AM
ScionGolf's Avatar
Default Stick Shift.
Just trying to get some advice on driving a manuel.
When I shift from 1 to 2 and 2 to 3, my car knock. What am I doing wrong?
Do I let go of the cluth then shift?
Old Mar 4, 2005 | 06:52 AM
trench's Avatar
NO DONT LET GO OF THE CLUTCH THEN SHIFT~ I'll cry if I heard the grinding of gears! OUCH!
Old Mar 4, 2005 | 06:53 AM
rsx_freak79's Avatar
never let off the clutch until the gear is engaged. are you sure you have it all the way in 3rd gear before you let off the clutch?
Old Mar 4, 2005 | 07:47 AM
Thread's Avatar
Awww come on, grind me off a pound.
Old Mar 4, 2005 | 08:10 AM
WaterDragon's Avatar
I think it's inherent in some tC's..... mine did for for a long while after I first purchased my tC, although I don't quite remember when it stopped
hope this helps
Old Mar 4, 2005 | 08:28 AM
TurboMe's Avatar
i think you should of sticked to AT. But ill give u some pointers this works well when racing also.
-Grab the stick and gently pull or push (depending on gear)
-depress the clutch
-shift
-release clutch
smooth shifting right there! u cnat go wrong.
Old Mar 4, 2005 | 10:09 AM
toyota_scion_tc's Avatar
have the clutch in all the way shift then let out. Don't shift too early though it does put a strain on your engine. I would go to at least 3,000 then shift.
Old Mar 4, 2005 | 10:51 AM
neuromonic's Avatar
You push in the clutch (all the way), then shift, then let the clutch pedal out. If you put the car into too high a gear for the road speed your motor will bog and knock. Is that what you're talking about?
Old Mar 4, 2005 | 11:58 AM
xnevergiveinx's Avatar
shift at 3000 rpm, but when you shift, let the clutch out slower, with a little more gas, you'll see the difference. i had the exact same problem you did. also, don't use 5th gear unless you are going over 50 mph you'll get better trust me
Old Mar 4, 2005 | 01:58 PM
niguels's Avatar
Default Re: Stick Shift.
To Clarify
Manuel is a male name in spanish. Driving a "Manuel" sounds funny, is like saying "driving a Pedro".
Manual is a type of transmission in which you use a stick to change gears.
just my 2 cents
Old Mar 4, 2005 | 02:04 PM
if it's the little "knock" I'm thinking of, it has nothing to do with the way ScionGolf is shifting.... as I posted, I used to get the same knock when applying the gas in 1st through 3rd, but only the first time after I let off the clutch in each gear. It's just a single knock that sounds like something in the car might be flexing and breaking in, I guess you could say
and before anyone thinks I'm a novice on M/T..... I've been driving manuals for about 20 years
Old Mar 4, 2005 | 04:24 PM
VW2SCION's Avatar
dang... mike how old are you?
Old Mar 5, 2005 | 04:59 AM
ScionGolf's Avatar
Sorry to all. I made a hugh typo in my post.
This is what I mean.
do I let go of the GAS (not clutch) , shift, release clutch , then GAS?
My 3th to 5th shifting are fine.
It's just 1st to 3rd. I shift when the RPM get to 3000.
The shifting does go very smoothly, I mean it's very obvious that I am shift during 1 to 3.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Mjdavis1994
Sep 21, 2015 04:42 AM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
Mjdavis1994
Jul 18, 2015 04:29 AM
