2011-____ [ANT20]
What I hate about New tC! Any fix suggestions?
Old Oct 4, 2010 | 05:01 AM
pharm's Avatar
Default What I hate about New tC! Any fix suggestions?
I hate all the road noise.... Is there a fix?
Also is the security system worth it? what does it do?
Old Oct 4, 2010 | 05:15 AM
draxcaliber's Avatar
install more sound deadening and insulation for less road noise.
as for security system. all a security system is is a theft deterrant, it can't really stop anything. does it help, yes, somewhat, but the main thing is prevention, like not parking your car in the ghetto, and not leaving valuables in plain sight like ipods and portable GPS.
Old Oct 4, 2010 | 06:08 AM
pharm's Avatar
This is what the website says "Protect your ride. Install the VIP SCION SECURITY System with auto re-arm, door lock / re-lock, interior light activation and 'panic mode features' for total peace of mind."
Not sure auto re-arm, doorlock/relock are?
Does this mean if I don't get the security system I would not get the panic button? why are they saying 'panic mode features'?
Old Oct 4, 2010 | 06:20 AM
jaylouie's Avatar
all keyless entry systems have a panic button. so you will have a panic button regardless of the scion security
Old Oct 4, 2010 | 06:23 AM
jnaval's Avatar
Auto re-arm is when you unlock/disarm the car while it's locked/armed, it will re-lock/re-arm itself if no doors have been opened within 30 seconds. And if the alarm ends up going off, it will always re-arm itself for another instance where it may go off again. The door re-lock is when the alarm goes off, the doors will automatically keep locking themselves. You can test it by sitting in your car, setting the alarm and manually opening the lock. You'll see it'll keep locking itself while the alarm is going off.
Old Oct 4, 2010 | 12:08 PM
1stOne's Avatar
It does have road noise, I will agree. But yes, sound deadening would help that out.
The security system also has a Glass Break feature where if someone breaks the glass, it will set the alarm off. Honestly it is worth it if you consider you get less features with an aftermarket system and when installed, will cost you the same amount.
Personally, other than the road noise (which I plan to increase with an exhaust), the car is very enjoyable to drive.
Old Oct 4, 2010 | 12:16 PM
Jon's Avatar
Jon
Moderator
Moderator
Ride in a first gen then see if you want to complain about road noise lol. That was one of the only things I liked about the car was that it was a whole lot quieter.
Old Oct 4, 2010 | 12:55 PM
pharm's Avatar
What is this "panic mode features"?
and why doesn't the website mention the glass breaking sensor?
Old Oct 4, 2010 | 01:31 PM
1stOne's Avatar
What website? Where are you from?
Old Oct 4, 2010 | 02:43 PM
pharm's Avatar
oh sorry, Scion.com
Old Oct 4, 2010 | 03:40 PM
DriverXa's Avatar
Just turn up the stereo, problem solved. lol.
What kind of tires did they stick you with? Those will play a role in the road noise if you got stuck with some crummy rubber.
Old Oct 15, 2010 | 06:41 PM
greenbean24's Avatar
The new tc doesn't have that ridiculous hatch rattle either. Thank god lol
Old Oct 18, 2010 | 02:37 AM
Vlad1024's Avatar
yet...
On a side note, when i bought my tc from the first round of '08s and got the alarm they did the lazy thing used last years harness which disabled the steering wheel controls. Took them three or four tries (and several scratched and replaced panels) to figure out what was wrong. Bottom line, dealers are bad at installing accessories and even worse at fixing the problems they cause.
Old Oct 25, 2010 | 12:06 PM
JJGeneral1's Avatar
1 fix suggestion, why only 1 back-up light?
Old Oct 25, 2010 | 02:51 PM
highvoltage1's Avatar
Dont you know. 1 is always better than 2!
Old Oct 26, 2010 | 04:34 PM
JJGeneral1's Avatar
no, but i know that 1 is the loneliest number....
and i also heard that the bird is the word!!!
Old Oct 26, 2010 | 04:45 PM
LOL
Old Oct 26, 2010 | 11:22 PM
oneshotted's Avatar
I got the manual 6 speed version,
tires are Yokohama Avid S34, the road noise is not so bad,
try a civic si, you will enjoy the noise level in your tC after that...
The only complaint i got for now is a vibration in the passenger door when you increase volume...may be subject to rattles in the future.
Old Oct 27, 2010 | 11:37 PM
oneshotted's Avatar
I discovered that when you Disable TRAC (Traction control),
it will re-enable itself at 30mph...
Is there any way to prevent this? A fuse where i could put a switch? any idea?
Old Oct 28, 2010 | 02:09 AM
Superpickel's Avatar
Come to a complete stop then press and hold the TRAC button. This will disengage it until the car is turned off and then on again.
