Dry Sump System.
Old Oct 9, 2010 | 04:25 PM
mileoutrage's Avatar
Default Dry Sump System.
On some finer details in my car plans I was looking into a custom dry sump system for my car, this will allow me to lower the motor 8-10mm helping with center of gravity and with heavy track use I wouldnt have to worry about oil starvation. < main concern
How much would identical full custom systems cost on our cars? I do know it is fairly expensive but would like to get a near estimate..
Would it be better to move to something like accusump?
Old Oct 9, 2010 | 07:25 PM
Ace83's Avatar
Ronin Scion
its only ptuning that i remember doing this, maybe they could chime in
Old Oct 10, 2010 | 02:47 AM
MrBurrito's Avatar
i believe WORLD Racing also has a drysump on the 2azfe i'll ask about it
Old Oct 10, 2010 | 03:58 PM
Thanks guys, Im hoping that the benefits greatly outweigh the cost on this, but if not ill have to try and run a accusump system somewhere, which essentially works great but lowering my motors center of gravity is out of the question.
If I do get the accusump, I may go with the manual valve kit.
Old Oct 10, 2010 | 05:50 PM
Spicy_McHaggiz's Avatar
Benefits will not outweigh the cost.
Old Oct 10, 2010 | 06:00 PM
bdis3's Avatar
Unless your building full race, track only car, I dont think it would be worth it. If you are however, go for it. I know world racing runs one on both of their time attack cars.
Old Oct 15, 2010 | 11:42 PM
TJKASS's Avatar
Waiting for others whove tracked these engines to chime in. Honestly one of the biggest benefits is the prevention (or lessening of) the chance of oil starvation. On hard, continuous right turns ive had to step out as my car has begun to lose oil pressure (as oil pools in the left side of the head and left side of the pan). Currently im looking into building a baffle setup if I decide to continue tracking this car (the funds for a full dry sump have been sunk into my new project). If you're still intent on tracking, then a dry sump makes perfect sense, as it will also allow you to add an oil cooler much more easily and have a much higher overall oil capacity, keeping oil and engine temps more stable.
TYLER
Old Oct 18, 2010 | 02:54 PM
speedintc's Avatar
i was thinkin about the same thing, im pretty sure that this is the reason i blew my motor. on a hard banked turn.
Old Oct 18, 2010 | 03:15 PM
Granted, its not the same motor but I had a 240sx with a rb25 that I ran into this problem with, if im going to end up dumping money in the motor I want to make sure that all parts perform is unison, not just focus on suspension/motor but also keeping critical engine areas in watch and able to withstand the forces of tracking.
ex. dry sump, tranny, axles, ect.
has anyone on this site heard of accusump?
Old Oct 18, 2010 | 03:18 PM
speedintc's Avatar
have you ever thought to look on jegs at like a moroso set up?
Old Oct 18, 2010 | 03:21 PM
speedintc's Avatar
http://www.jegs.com/i/Moroso/710/23903/10002/-1 this one is supposed to work well with smaller engines.
Old Oct 18, 2010 | 04:36 PM
oh nice find speedinc, Imma look into it,
heres accusump
http://www.racerpartswholesale.com/category/Accusump2
on this site it also has the supporting stuff you would need for this
manual valve or EPC valve
http://www.modified.com/projectcars/...ump/index.html
^ this is on a s2000 track car
Old Oct 18, 2010 | 04:47 PM
speedintc's Avatar
yea man i will probably eventually end up doin this set up, im about to drop a pretty penny in my motor build so id rather it not fail on me.
Old Oct 19, 2010 | 06:31 PM
DezodDon's Avatar
3-5k depending on how involved you get.
Old Oct 20, 2010 | 12:01 AM
bdis3's Avatar
^ yep That's why I suggested it for a pure race car. I'd get the accusump system if I was doing it.
Old Oct 20, 2010 | 12:47 AM
Un4Scene's Avatar
From: Living in the Omaha, NE area, traveling all over the continent
TYLER
I'm curious to see what you come up with for a baffle setup. Are you talking about baffling the oil pan or the head? If you do this, post some pics up and let us know how it worked out!
~Laken
Old Oct 20, 2010 | 08:56 AM
speedintc's Avatar
i dont thinkk that it is for pure race car drivers. it obviously could be beneficial for corner carvers and people who do frequent track days but daily their vehicles. all in all wat makes it out to be a 3-5k set up?
Old Oct 20, 2010 | 11:23 AM
bdis3's Avatar
The 3-5k price tag makes it for serious owners.
Old Oct 20, 2010 | 11:39 AM
speedintc's Avatar
well from wat i have found i dont see it costing that much to set it up.
Old Oct 20, 2010 | 02:58 PM
DezodDon's Avatar
Depending on what stage pump you go with, lines, fittings, custom oil pan, in this case a custom pulley for the belt, etc.
