well after the two power adders i've added (k&n drop in filter and the trd muffler)
my power band seems too kick in at around 3K rpm :)
i'm glad they both seem to be helping each other on my some what budgeted power quest
i'm likin it a lot and a lot!!! :clap: :clap: :clap:
xmetalx
03-05-2005, 08:58 PM
spend 150 on the injen short ram and 90 on the megan header.
jct
03-06-2005, 12:17 AM
i'll pass on the intake and the megan header, i'm planing on getting DC Ceramic Coated header and Denso Iridium Power Spark Plug
FrankenScion
03-06-2005, 12:35 AM
Can't go wrong with K&N.
Do those iridium plugs really make a difference?
jct
03-06-2005, 12:46 AM
from what i'm hearing, they say you'll gain 5 extra hp at the wheels on stock 4 cylinder
and 15 extra hp on F/I at the wheels
i'll let you know if they work or not...
i'm the kind of guy likes to feel the power in the seat of my pants
FrankenScion
03-06-2005, 12:47 AM
Word!
jct
03-06-2005, 12:51 AM
Word!
i'll be getting 'em with in this month or next
i'm ordering my header next week
Mista3
03-06-2005, 01:01 AM
the only reason I didn't buy the TRD muffler was because I didn't know what it sounded like. Does it sound ricey or more american muscle car?
killerxromances
03-06-2005, 01:12 AM
Not to argue or anything, but if plugs can get you up to 15hp, you should be able to pull around 8 to the wheels. I have my doubts the gains will be this high though by just swapping sparks. Maybe 3-5hp gain i'd say... Oh well, not trying to start anything with anyone! Good luck!
cya
FrankenScion
03-06-2005, 01:22 AM
I really don't like high-pitched ricey pipes. I have the TRD pipe and I love it. It is not high-pitched at all. Sounds real nice.
Kong
03-06-2005, 01:26 AM
Denso Iridium makes very little different. It does help a bit at > 3krpm. I've tried it.
jct
03-06-2005, 01:29 AM
it has a nice rumble sound when you get on the gas, and you can't really get that nice american V-8 sound out of a 4 cylinder not very easily i think,
cya
heres the info i got on the spark plug/on what i'm going off by
"Gains of 5+ WHP can be seen on stock 4 cylinder engines, simply by switching from conventional spark plugs to Denso Irdium Power plugs. The horsepower gains can reach 15+ WHP on turbocharged race engines."
Forced induction or not, theres no way swaping sparks will give you 15whp, not for $15.00-$20.00. Using aftermarket sparks really just help the sparking. I mean, its not complex at all. Suppose to help with turn overs (starting engine) and the such. Plus its a good idea anyways when you are wanting to do major upgrades under the hood. But i have never seen just swaping sparks get you 15 to the wheels, i've never even heard of that. So i call B.S. on that site. It's still a good idea to do it man, but i disagree with the numbers they post.
cya
unlmtdndeavor
03-06-2005, 10:13 AM
cya
^^^^ no power comes that easy
jct
03-06-2005, 12:20 PM
but its worth it though
killerxromances
03-06-2005, 11:06 PM
Thats exactly what i was saying! If it were, we would have more Scion Xb/Xa's with 200hp.
Derk-xB
03-07-2005, 12:22 AM
Congrats on your new found power. 8)
From what I've read/learned, new plugs will only replenish lost hp.
Why is it lost? Wrong plugs, fouled plugs, worn plugs, etc etc.
But, using a quality plug should certainly help with a clean and efficient burn. So, if they're not too expensive, I don't think there's any harm. Plus, they look like they're super easy to access (easy to change).
unlmtdndeavor
03-07-2005, 08:43 AM
thats right, no harm to have them. and yes, just pull the engine cover off, then pull unscrew the coil packs and pull out the plugs
Tamago
03-07-2005, 01:20 PM
no gains from iridiums :) but i like my 100,000 denso's
Fujiz_xb
03-07-2005, 02:13 PM
congrats on the extra hamster power
mo2
03-08-2005, 11:48 AM
quick question what kind of spark plugs come stock on an xa/b
Lonely_Raven
03-08-2005, 12:39 PM
I've posted this before, and I can't find the link now, but the
Porsche club did extensive testing on spark plugs and
performance on everything from $20,000 4 cylander Porsches
to $250,000 Twin Turbo 911, and they found that simple
$2 copper core plugs perform the best. The Iridium only
give you longer plug life, and for some reason the platinum hurt
the performance on *most* Porsches.
As stated above, most "performance" increase found in
plugs it's just from having fresh ones in there with the proper
gapping.
shad0w
03-08-2005, 12:51 PM
I did have good luck using Iridium plugs in a motorcycle a few years ago. I can't say that peak power was affected. Before I put the plugs in the bike had a flat spot around 5000 rpm {even with new standard plugs}, after I put the plugs in the flat spot was gone. Result was better rideability on that bike even if it wasn't really faster. I think it has something to do with the Iridiums being able to deal with lean mixtures better. If your car is tuned better than my bike was, you won't see much improvement, but why not give it a whirl?
