just installed 5mm spacers. 4 3/4 lug nut turns safe?
Old Oct 23, 2010 | 07:40 AM
Tom11x's Avatar
Default just installed 5mm spacers. 4 3/4 lug nut turns safe?
just wondering 4 3/4 lug nut turns is it safe
install 5mm spacers in the front today. its finally flush but was wondering 4 3/4 enough?
Old Oct 23, 2010 | 06:09 PM
Tom11x's Avatar
anyone?
Old Oct 23, 2010 | 08:27 PM
Spoony's Avatar
I believe you should be fine. Some people run 8mm spacers; just make sure to torque them correctly.
Old Oct 23, 2010 | 08:38 PM
HKSpeed's Avatar
Drive 100 miles and check to see if theyre loose. It should be fine if theyre torqued right. Are they generic or hubcentric?
Old Oct 26, 2010 | 08:23 PM
ExpresScion's Avatar
I have 5mm hubcentric in the back. Torqued them to 90 and they haven't moved since.
Old Oct 26, 2010 | 11:04 PM
Ace83's Avatar
Ronin Scion
should you torque more when running spacers or we can just torque it to oem spec, im planning to run 15mm
Old Oct 26, 2010 | 11:34 PM
Wow, 15mm seems like too much. I've heard of 8 being done, but never 15. You might want to look into extended studs.
Old Oct 27, 2010 | 12:09 AM
Ace83's Avatar
Ronin Scion
spacers comes with studs though
Old Oct 27, 2010 | 04:21 AM
Tom11x's Avatar
get adapters. i got a inch on the rear
Old Oct 27, 2010 | 01:38 PM
Ok, that makes sense. I thought you were talking about the little hub centric slip ons.
Old Oct 27, 2010 | 10:12 PM
Wheeldude.com's Avatar
It is safe to run 5mm spacer on stock studs. Make sure you torque you wheels down in a star pattern and to the correct torque spec. Anything larger requires extended wheel studs.
-Tommy
Old Oct 29, 2010 | 03:48 AM
Tom11x's Avatar
thanks guys for the info will check once it hit 100miles
scionlife
371
Jun 2, 2015 11:00 PM
HeyyJose
Mar 11, 2015 02:15 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
