Heated Seats 2006 tC
Old Oct 28, 2010 | 01:00 AM
reelknead1's Avatar
Default Heated Seats 2006 tC
Alright guys,
This might be a tough one because they normally aren't on scions but i have a 2006 tC with heated stock seats that were a dealer add on when I bought the car. I have no idea how they did it or how they would do it. But my driver seat stopped working but the passenger one is working normally.
What do you guys think the issue could be, what should i check?
I was thinking maybe a switch issue?
I was leaning away from a fuss because i would assume that they would put both seats on one fuss but could be wrong.
All the plugs under the driver seat are plugged in so its not that.
Any ideas on diagnosing this would be great. Winter is around the corner and I would like it working again but would rather not take it to the dealer, just for cost purposes.
Old Oct 28, 2010 | 01:26 AM
SCIONOSIS's Avatar
Most commonly the heating pad under the fabric/leather seat develops an open circuit (broken wire or broken element) from flexing and stretching apart due to getting in and out of your seat over time. But other things can cause inoperative heated seats, like a blown fuse or a disconnected connector. I believe you have a defective heating pad. If you access that plug under the seat, get a multimeter and see if you have continuity. Or try giving B+ supply and gnd directly to that plug to check if it's warming up the seat.
Old Oct 28, 2010 | 01:43 AM
reelknead1's Avatar
The heating element would make the most sense because the passenger is working which doesn't get used nearly as much.
What fuse location would they use? Do you have a fuse diagram?
Old Oct 28, 2010 | 01:58 AM
SCIONOSIS's Avatar
Well, it's not factory installed, so that kind of information is not available anywhere. It would depend on who installed it. Although, I've seen most of these aftermarket heated seats getting their B+ supply from the underdash fuse block. There is probably a wire fuse splice connected to one of the vehicle's fused circuits. I don't know how it's installed on yours, but usually that wire I mentioned would have an in-line fuse. Just follow down that wire if you see one attached to the fuse block.
Old Oct 28, 2010 | 02:09 AM
reelknead1's Avatar
I'll take a look for it in the morning. Thanks for all the information and i'll try and keep you guys updated
Anyone with any more information or things i should check please chime in.
Thanks again for the info.
Old Oct 28, 2010 | 02:14 AM
SCIONOSIS's Avatar
Welcome. Glad to help you out.
Old Dec 28, 2011 | 03:33 AM
Pikefrodo's Avatar
Hey guys I have a 2006 Scion tc wih stock heated seats. Both driver and passenger seats aren't heating. Any troubleshooting ideas? The fuse box diagram in the car doesn't show what fuse it is - do you know which one I should check? Appreciate any help!
Old Dec 29, 2011 | 03:21 AM
chubbykai's Avatar
lol wahtt... i want heated seats in mine!
oreoremix42
Apr 8, 2015 01:06 PM
gp1817
Mar 18, 2015 10:26 AM
boxmobile
Mar 7, 2015 02:54 AM
Kiwibox
Dec 15, 2014 09:46 PM
Dylan
Feb 18, 2004 02:50 PM
