Installing Seibon CF hood
Old Nov 3, 2010 | 07:58 PM
xAdverse's Avatar
Default Installing Seibon CF hood
Hi everyone!
Im a big Fan of TCs! i just came over from CSTC.
I just wanted to know what i need to install my Seibon hood.
Just wrench or what? its supposed to arrive at my house in like... an hour hahah x]
Old Nov 3, 2010 | 08:09 PM
maximthegreat's Avatar
ratchet, 14mm socket and a friend
or was it 12mm (I can't remember so have both just in case, unless someone else wants to chime in)
Old Nov 3, 2010 | 08:25 PM
skinnayyy's Avatar
Team Scionara
i don't know if seibon is the same as kanamari, but the bolts they gave me were different size than the OEM bolts. So, a 14 and whatever seibon gives you.
Old Nov 3, 2010 | 08:26 PM
skinnayyy's Avatar
Team Scionara
oh, and another person, because holding it up while trying to bolt it down is not fun by yourself, even if it is CF.
Old Nov 3, 2010 | 09:05 PM
I have kaminari and used stock bolts
troof
xAdverse's Avatar
I cant take off the water hose without taking off the black part on the OEM hood?
how do i take the black part off? i tried pulling it pretty damn hard lol
Old Nov 3, 2010 | 09:41 PM
Pop out the black tabs
Old Nov 3, 2010 | 10:08 PM
xAdverse's Avatar
Now i have a second issue i put the hood on aligned and everything but now
The Nozzle wont fit through the Seibon Vis II hood...
can someone help me out? How do i put the water hose through as well?
Old Nov 3, 2010 | 10:10 PM
xAdverse's Avatar
ill post pictures when i get home from work... driving now with the hood screwed in by washers and
without the sprayer~ Thanks for any tips!
Old Nov 4, 2010 | 06:34 PM
TotalChaos's Avatar
Hey man, sounds pretty to install minus the washer nozzles, etc. Were the holes predrilled? Also, what is the approximate weight difference b/w the hoods? Feedback much appreciated.
Old Nov 4, 2010 | 08:32 PM
xAdverse's Avatar
The holes were pre-drilled for the washer nozzle...
I read around ALOT and it seems i have to use a dremel and drill it a little bigger.
Great x[
Anyways
Weight Differance? HUGE!!!
and thats not an exaggeration.
It took me and another strong guy to carry the OEM. Both of us work out and id like to think we are stronger than the average guy.
I could carry the CF one by myself. EASILY.
Old Nov 5, 2010 | 08:12 PM
skinnayyy's Avatar
Team Scionara
the dremel is basically the only way to drill out the washer nozzle. or other preferred method of doing the same thing. i wish mine were pre drilled on the kanamari. they just have dimples of where they should go. so i'm rocking no nozzles because i'm lazy
Old Nov 5, 2010 | 08:20 PM
jazfromhouston's Avatar
Great x[
Anyways
Seriously? OEM hood weighs maybe 50lbs max. I carried mine to put in my greenhouse holding only the latch. My carbon fiber hood one can be picked up using one finger on the hatch.
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
Archangel1183
Feb 24, 2015 09:51 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
