View Full Version : TRD supercharger question that hasn't been asked already!
neuromonic 03-07-2005, 11:54 AM Maybe there should be a FAQ sticky. Anyway here goes.
I know the new TRD sc is going to be centrifugal as opposed to their previous offerings that appear to be roots style. I also understand that an intercooler will not be part of the 'stock' configuration. I don't see how it could be for the intended price-point that they are trying to hit. It would be silly for them not to offer one as an upgrade though, as every FATF watching kid is gonna want a huge front-mount with a loud BOV... but I digress. My question is does anybody know wtf the following quote means. It is from the TRD website regarding their sc for the matrix.
Supplemental TRD ECU provides recalibrates engine management for optimum Supercharger performance. Systems includes supplemental injectors that create an "intercooling effect," permitting higher boost levels for increased efficiency and enhanced power and torque.
Does this mean the ECU upgrade is a piggyback? Supplemental implies a secondary. I think piggybacks are a pretty half-___ way of fixing the fuel and timing curves. The second part about supplemental injectors. Is the 'intercooling effect' that they are talking about simply dumping more fuel into the cylinders? That's kind of what it sounds like. (It does provide a cooling effect, but I would hardly consider it "Intercooling"!) I wonder if the tC is going to require upgraded (or additional?) injectors. I know the aftermarket TURBO kit that everyone is talking about has some sort of fuel solution, but they aren't very forthcoming with the details (which is not a good way to sell turbo kits BTW). Probably injectors and an in-line fuel pump. I'm sure the stock SC will handle a significant amount of boost assuming it is properly cooled and fueled.
Any thoughts?
engifineer 03-07-2005, 12:53 PM The ECU upgrade is supposed to be a flash upgrade. I was told that that is one of the issues they are working out, which is holding the release. They are working out bugs in the flash version they are using. I am not sure why they would call bigger injectors an "intercooler effect".
From what I have been told by Scion, the SC will provide 5-6 PSI of boost and will include the flash upgrade to the ECU as well as larger injectors. Should be somewhere between $2700 and $3000. That is all I have been told so far. Hope this helps.
bambams247 03-07-2005, 07:09 PM Well I am asusming that larger injectors will be used, and that our fuel pump is already ready for the s/c. And I wish they offered an intercooler option for the car, but we have that bottom grill with optional fog lights in it that doesnt let much air pass by........... I'll be happy with a nice stock TRD setup
HighlanderMac 03-07-2005, 08:16 PM Supplemental injectors means there aare added injectors in the intake manifold. This will add more fuel meaning it would not be necessary to get larger injectors (possible) You may still need larger injectors, but that should take away the need for supplemental injectors.. Hope this helps you out a little bit.
TurboMe 03-07-2005, 09:22 PM I thought u cant add a BOV to a SC...
jrv2000 03-07-2005, 10:35 PM I thought u cant add a BOV to a SC...
you can
Mediocre_Generica 03-08-2005, 01:30 AM If thats what they're really saying, I'm disappointed. Piggyback engine management, ghetto "intercooling effect," additional injectors instead of improving whats already there...
Fortunately one of the fliers they handed out at the NAIAS had a picture of the kit, complete with four injectors. I doubt they'd add four to the four already there, so I think it's a safe bet they'll be replacing the stock ones with improved units.
ajnast4r 03-08-2005, 01:59 AM intercooling effect is just a stupid way to say they are gonna make the car run rich as hell
neuromonic 03-08-2005, 12:48 PM ajnast4r, that's pretty much what I expected. When I hear "intercooler effect" I was hoping for something cool and hi-tech like water vapor injection, but at the price I, too, figure that "intercooling-effect" meant "dumping a whole ton of extra fuel to keep the cylinders from getting too hot".
I've heard it bandied about that the sc offered is going to be a vortech product. Are the other TRD sc's vortech products?
JasonH 03-08-2005, 01:43 PM Yes, the tC TRD SC will include a piggyback ECU (instead of the flash that was originally proposed) and will also includ the extra fuel injector. Additional "staged" upgrade may be available in the future, including intercoolers and BOVs.
SupaWhiteTc 03-08-2005, 03:52 PM It is the same as the TRD Supercharger ECU for the Corolla and Matrix. It is a new replacement ECU that has different fuel maps to richen up the A/F mixture so you can run higher boost without leaning out. It is not rocket science. The supercharger for the TC doesn't come with a 5th injector like the others it comes with a whole new set of injectors that are bigger.
neuromonic 03-08-2005, 09:41 PM Supawhite, the matrix and corolla supercharger kits come with a "replacment" ECU and not a piggyback ECU? The TRD site says a "supplimental" ECU. To me that implies a piggyback unit.
Whereas a reflash would load completly new fuel/timing maps into the stock ECU, a piggyback unit typlically sits in between the ECU and the sensors and modifies the signals to provide the appropriate changes.
Unichip is an example of a piggyback that works with toyotas, for example.
skinny 03-08-2005, 09:52 PM as we have already seen supawhite doesn't know much since hes the one that did the "budget exhaust" on his car oh yeah but its not rocketscience.
engifineer 03-08-2005, 10:46 PM Yes, the tC TRD SC will include a piggyback ECU (instead of the flash that was originally proposed) and will also includ the extra fuel injector. Additional "staged" upgrade may be available in the future, including intercoolers and BOVs.
I'm not doubting your info, just wondering what source you heard it from, as it is almost opposite from what scion told me. I was told that the reason for the delay in release was to work out bugs in the flash download. I also heard that they are replacing all of the injectors. Again, not doubting you, just wondering if you had a better source of info than me. Thanks.
itimebomb 03-09-2005, 06:00 PM i love hearsay. i have some more.
i seem to recall when TRD was at my dealership a few months ago that:
the delay was caused by emissions testings. the initial 40hp increase was changed to 80ish and more testing had to me done. he mentioned the cpu being flashed, due to the fact that this is the first time in toyota history that the engineers in japan have released the engine codes (even to TRD) so that optimum air/fuel curves could be determined. and bigger injectors, not extra ones.
xravexboix 03-09-2005, 08:01 PM i love hearsay. i have some more.
Quite true. Toyota Corp. has never released ANY specific engine fuel mapping or other measurement specs for public (or even internal) use UNLESS it's absolutely necessary for repairs (.001% chance of it being needed haha).
I've seen one of the prototype superchargers in person... some guy in Ventura stole it and I went to check it out (buy it!!) and saw hoses cut and stuff... so I contacted TRD before any of the 2AZ supercharger announcements were made and they said "Yes, we have a prototype and WHO THE HELL HAS THAT ONE?!" but this was quite a while ago... I think a year and a half now... (Oct 03ish, pre tC announcement, I have a 2AZ Solara). It is centrifugal for sure (check out the RIPP S/C for the 5S-FE, looks like that)
From what I read in technical articles, the SC specs (quoted exactly as found in the technical article, as of 10/19/2004):
TRD supercharger (late introduction)
a. power target = 200 Hp @ 5 psi
b. compant, efficient, quiet Vortech scroll compressor
c. pumps up "off the line" torque out put for max driving fun
d. unique packaging and installation, drive by jack-shaft
1) designed for ease of dealer installation
2) warranty = factory engine warranty
e. integrates with factory engine management:
most sophisticated OEM supercharger system developed by TRD
1) includes new fuel injectors
2) "piggy back" ECU
3) previous TRD production systems:
1MZ-FE (Camry/Solara)
3VZ-FE (Tacoma, Tundra, pre-03 4Runner)
2UZ-FE (Tundra, Sequoia, LC-100)
I'll look for any updated articles when I have extra time today.
davedavetC 05-12-2005, 05:57 AM I thought u cant add a BOV to a SC...
you can
i hope you really can put a bov on a sc because that would be awesome and i would get the sc as soon as i get the money (or as soon as it comes out lol which ever comes 1st)(well if i had the money first that means i would still have to wait lol :tap: :tap: )
JakeMafia 05-12-2005, 05:42 PM whats the point of having a BOV on an sc? besides the sound of pssssshhhh,
TheQuietThings 05-12-2005, 06:13 PM seriously, it sounds like hes buying the SC for the sound of the BOV, and not the added power.
JakeMafia 05-12-2005, 06:47 PM ya but that wouldnt make any sense, y spend about 4g one a sc to get the BOV, when you could get a turbo kit for alot cheaper just run it at like 3 psi, that will prob make more power than the SC,
NY_BSP_Scion 05-12-2005, 07:00 PM Fortunately one of the fliers they handed out at the NAIAS had a picture of the kit, complete with four injectors. I doubt they'd add four to the four already there, so I think it's a safe bet they'll be replacing the stock ones with improved units.
This is what http://www.mcgeorgeparts.com/ has as the kit they will be selling (of course when avalible.)
http://i5.photobucket.com/albums/y188/tikigod42/.jpg
CLEANTC 05-12-2005, 07:00 PM are we sure that you need a bov on a supercharger or do we just think that there will be? it make scence that there would be , being that you would want to be sitting at a light while its built up at 5psi right? ?
JakeMafia 05-12-2005, 07:04 PM no the BOV wont come standard, cuz usually SC dont have BV just that loud whirrring sound coming from the engine.
NY_BSP_Scion 05-12-2005, 07:08 PM If your pushing higher psi's on a supercharger then a b.o.v makes sense, but a supercharger has more of a linear power band then a turbo so pressure isnt built up fast enough to require it to be purged.
The b.o.v does serve a purpose other then making a cool sound. :D
turbocivic 05-12-2005, 07:14 PM belts are for holding your pants up....get turbo'ed.
JakeMafia 05-12-2005, 07:19 PM I know the BOV serves a purpose, but mostly only on turbo cars, do ever hear GTP's with BOV, or superchrged, cameros, or ne car, BOV dont really serve a purpose on a SC, it does on a turbo
NY_BSP_Scion 05-12-2005, 07:37 PM I know the BOV serves a purpose, but mostly only on turbo cars, do ever hear GTP's with BOV, or superchrged, cameros, or ne car, BOV dont really serve a purpose on a SC, it does on a turbo
Sorry if you thought the comment was directed at you, it was just to the people that want one for the sound not the purpose. Only time ive ever seen a b.o.v used with a supercharger was on a twin-supercharged sc430, and that i can see why.
davedavetC 05-12-2005, 08:18 PM ya but that wouldnt make any sense, y spend about 4g one a sc to get the BOV, when you could get a turbo kit for alot cheaper just run it at like 3 psi, that will prob make more power than the SC,
except that the supercharger is installed by the dealer and comes with a 5 year/ 60,000 mile warranty, or somethin like that.
if anyone knows of a turbo that comes with a warranty like that lemme kno. thanks
davo345 05-13-2005, 01:20 AM belts are for holding your pants up....get turbo'ed.
haha if I didn't want the SC, I would put that in my sig...nice quote man :rofl:
surfcity40 05-15-2005, 03:21 AM is this the final? (sry if it's a repost)
http://gallery.scionzone.com/gallery/tcsupercharger2004
NY_BSP_Scion 05-15-2005, 05:00 AM is this the final? (sry if it's a repost)
In the thread below i wrote:
"Yes it is the trd supercharger. From a show awhile back where toyota brought a tc with it. This is the final so it will look the same.
*edit. a friend just told me that this is what the trd supercharger will look like but that this wasnt a working version toyota brought to the show."
http://www.scionlife.com/forums/viewtopic.php?t=62969
As for what my friend said i think i remember hearing that but its up for debate where its true. I know they put a working version on the scion pace car: http://www.scionlife.com/forums/viewtopic.php?t=61309
TimmyT 05-15-2005, 06:21 AM From my understanding a b.o.v releases pressure in your system during shifts to reduce wear on engine compnants.. and sounds cool. So I have no idea why a bov wouldn't be wanted in a s/c system or why it couldn't be applied
NY_BSP_Scion 05-15-2005, 06:28 AM From my understanding a b.o.v releases pressure in your system during shifts to reduce wear on engine compnants.. and sounds cool. So I have no idea why a bov wouldn't be wanted in a s/c system or why it couldn't be applied
For the same reason i posted on page 1:
"If your pushing higher psi's on a supercharger then a b.o.v makes sense, but a supercharger has more of a linear power band then a turbo so pressure isnt built up fast enough to require it to be purged."
hope that helps.
dachmo 05-16-2005, 07:37 PM are we sure that you need a bov on a supercharger or do we just think that there will be? it make scence that there would be , being that you would want to be sitting at a light while its built up at 5psi right? ?
Superchargers do not run off of the exhaust gas..... therefore, when you are at an idle, they are not producing boost.
NY_BSP_Scion 05-16-2005, 08:18 PM Superchargers do not run off of the exhaust gas..... therefore, when you are at an idle, they are not producing boost.
It's the other way around at idle turbos do not produce boost because there isnt enough exhaust gas (hence turbo lag while turbo spools up on acceleration) But a supercharger is run off of the drive belt which is spinning the supercharger during idle, although producing little boost at idle its already spinning along with the drive belt so boost comes on at low rpm and builds.
prototype 05-16-2005, 08:47 PM i havent seen anyoe ask:
what does trd plan for the gauges?
If a piggyback system is utilized will the engie rev higher? whar about boost and a/f?
i assume gauges would be needed or at least would make sense...
do they plan on slappinn em on the a pillar ( garbage ) or change the stock gauges out for new ones?
anyoe know?
jrv2000 05-16-2005, 09:02 PM i havent seen anyoe ask:
anyoe know?
I am pretty sure that this system will not come with any type of guages. If you want one your going to have to go aftermarket.
prototype 05-16-2005, 09:06 PM sucks....
just seems for the price for a "complete" kit. It should be included.
why spend 4k... then hae to go spes a few hundred more just see if the car is runnig properly.
The more I hear... the less i want the system. and I want it.
Just bought my tc 2 weeks ago. used with 8k miles for $16.5k =0)
now, Im working on sposership... yay me!!!
