View Full Version : Question to lowered xB Owners
Sid_xBicious 03-07-2005, 05:20 PM this is in regards with the rear wheels.
My passenger side rear wheel is more flushed out compare to the driver side.
and also,
http://groups.msn.com/_Secure/0TQBKA*AVXDy!jBy0xLmDkCIhjtkvl7qrsqUWp5kzs0jAyPMAFhQnrqe2jjNeEdBqQmDBcPff6yHAoRSMjw5e!GMhBnUoLB7NhH1rhRKx*3HPPD645TDwcA/IMG_0977.JPG
the clearance(mark on yellow arrow) on passenger side is a bit narrower compare to driver side.
The question is:
Does anyone notice the same in your xB?
I can't find the thread that discussed this before, so I want to verify it again, and wanted to know Scion's explanation.
thanks,
TheDanger 03-07-2005, 05:23 PM nope not me...mine seem the same
Sid_xBicious 03-07-2005, 05:44 PM thanks, I see you have '05. Any other input from '04 models?
appreciated,
TheDanger 03-07-2005, 06:06 PM now wait I thought you were talking about the top fender...ok maybe your skirts are shifted different. See how far your skirt is away from the fender
Sid_xBicious 03-07-2005, 06:22 PM now wait I thought you were talking about the top fender...ok maybe your skirts are shifted different. See how far your skirt is away from the fender
no, my 2 question are:
http://groups.msn.com/_Secure/0TQAhA!0VkDu!jBy0xLmDkNZqrudiKSHqBSqDeMWdqhFSR7oyVipdaHIevAa*GTEWZCb!g7nkqDRta3LHWQ8OB*mD5i3CsohNAdq97043GWEVOYx5pgwxJA/IMG_0974.JPG
passenger side
http://groups.msn.com/_Secure/0TQDvAu4V1Du!jBy0xLmDkNUam!R*nccyV7cYUM4bqZfjzHvM*hu0kVRUklkoch6*vOVYiB*s2Mfujm8UCrzstBzgPjlcIdPIBlPP5ls4YTDH2zd4eigjpQ/IMG_0975.JPG
driver side
not a good shot but, see how passenger side is more flushed out compare to driver side?
2nd question is the clearance of the wheel to fender side, not the skirt.
thanks,
dgHotLava 03-07-2005, 06:31 PM the offset to the pass. side is normal....
as for the tire being shifted forward (very top post...)
i will have to look at mine later, but i don't think mine is like that...
JohnAkaB 03-07-2005, 06:33 PM take out your wheel and re-install you probably forgot something
Sid_xBicious 03-07-2005, 06:34 PM the offset to the pass. side is normal....
so is both of your rear wheel evenly flushed?
thanks,
DJ_X_Trodinaire 03-07-2005, 06:36 PM this was talked about loooooong time ago
i remember reading that it was normal
Fujiz_xb 03-07-2005, 06:39 PM i see your prob...that looks akward.. not sure what the deelio is.
Sid_xBicious 03-07-2005, 06:43 PM this was talked about loooooong time ago
I know, but can't find that thread. I don't remember Scion tech answering why.
TheDanger 03-07-2005, 06:47 PM mine seems the same...I will have to check after work...looks wierd for sure
scions front nead wheels 1\4 to 1\2 spacers on aftermarket rims i've done about a dozen or so
yesti 03-07-2005, 08:13 PM does the xb have a panhard rod? if so, that would need to be shortened to re-center the axle relative to the body.
Sid_xBicious 03-07-2005, 08:24 PM take out your wheel and re-install you probably forgot something
thank you for your input :ponder:
but what possibly can you forget, wheels and 4 nuts :doh: j/k
BTW, there is no noticeable vibration and the car still drives straight(no hands on steering).
CBSIMONSEZ 03-07-2005, 08:55 PM The difference in the rear is from the factory The drivers side sits in more then the passenger side does. If it bugs you that much, then get a set of 3MM and 5MM wheels spacers. Put the 5MM on the drivers side, and the 3MM on the passenger side. This should level it out a little better.
The wheel shimmy up front may be from several things. First, check to make sure that all the lug nuts are tightened. Then, check the PSI in the front wheels. I had the shimmy, and brought the PSI up to 33 PSI on each of the fronts, and the shimmy has all but gone away. If this doesnt work, then you will need a set of hub centric rings. This device will make sure that the wheels are centered on the hub while you are installing the wheels. Sometimes the wheels are exactly centered, and this can throw off the driving. Hope that helps.
bB2NER 03-07-2005, 08:55 PM In reference to the first pix, my pass rear wheel is 1/4 inch farther forward than the dr. side. Is there an adjustment to make them match or is this the way they were designed??? :nails: :lalala:
Sid_xBicious 03-07-2005, 09:05 PM Chris,
thanks, I did check the tire pressure and set it to 35 psi. Yes I don't have centric rings, but slowly and carefully torque(cross pattern) the nuts evenly when I mounted it. I drove the car to 60mph and did not notice any vibration.
I will still get the rings($5) as soon as its available(54.1-67) in my nearest tire shop.
thanks,
Sid_xBicious 03-07-2005, 09:08 PM In reference to the first pix, my pass rear wheel is 1/4 inch farther forward than the dr. side. Is there an adjustment to make them match or is this the way they were designed??? :nails: :lalala:
this is what I need to know. TSB?
anyways, as long as it won't wear my tire quickly(tiger paw) I hope, then I guess I have to live with it.
thanks,
bB2NER 03-07-2005, 09:28 PM Yes, The rings are nice because you can hand tighten the lugs on the rear, then lower the jack and finish the tightening the lugs. Also it takes some of the weight off the studs and places it on the center hub.
luckydog 03-08-2005, 12:07 AM have someone drive behind you and see if the front and rear wheels track along the same line. the car can still go straight but the frant wheels and rear wheels run in different tracks. more common than you might think if that is the case they need to be aligned to the same thrust line. has the car ever been rear ended? to me the way there are now should not be considered normal.
metalicxb 03-08-2005, 02:33 AM could be two diff offset on wheels
CBSIMONSEZ 03-08-2005, 07:55 PM could be two diff offset on wheelsNot likely, seeing as how quite a few '04 owners have noticed this problem as far back as a year ago.
To the gap difference on the passenger side vs. the drivers side; talking about the front to rear gap, i havent noticed, but ill make a mental note to look once the snow stops here in NJ.
bB2NER 03-08-2005, 10:55 PM could be two diff offset on wheelsNot likely, seeing as how quite a few '04 owners have noticed this problem as far back as a year ago.
SNOW... :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
TheScionicMan 03-08-2005, 11:01 PM Thanks for pointing out the side to side difference. Now, it's gonna bug me too... Grrrr... :wink:
dgHotLava 03-08-2005, 11:02 PM could be two diff offset on wheelsNot likely, seeing as how quite a few '04 owners have noticed this problem as far back as a year ago.
may a tornado come through your trailer park...
j/p...j/p...
