what may be wrong?
Old Nov 22, 2010 | 04:18 PM
sciontc1207's Avatar
Unhappy what may be wrong?
Alright here what's going on.. I've been driving around and notice that clutch started slipping.. started only in 5th gear and during 3-5 under a lot of acceleration..then started to get worse and other gears doing same.. well ordered new clutch and flywheel.. well been driving back and forth to work cause only 3 miles away.. so on to the next and my main worry.. went to start car and pressed in clutch and started but started to shutter and made some noise I made sure was in neutral and went to start and and started and shut off.. and now when I press clutch in and start it make a whine noise.. and doesn't start. Everything lights up and got plenty of juice.. makes noise like if car is started and u crank it again.. kinda only way I can describe the sound... so what could this be other than clutch?
Old Nov 22, 2010 | 04:30 PM
johnnyb305mia's Avatar
The noise u hear sounds like ur TOB
SENT FROM MY VIBRANT
Old Nov 22, 2010 | 07:54 PM
tokenride86's Avatar
how many miles on clutch? u beat on it sometimes? be honest , most of us do it too lol
Old Nov 22, 2010 | 08:22 PM
Id say close 25000 miles cause its a aftermarket clutch was put in 2 1/2 years ago... and yes im very hard on and beat it sometimes.. Im a very aggressive driver...
Old Dec 1, 2010 | 03:06 PM
alright guys needs some more help... shop doesnt want to pull transmission until can get to run..says dont want to charge to have put in and then still have motor issue with not starting... i advsd sounds like the TOB. But they say they pull code for the cranksshaft postion sensor.. but they say that everything turns but car will not start.. they are recommending another shop take look at that deals with more motor stuff.. once again push clutch in and turn key it just makes a noise and kinda to hard to describe.. sounds kinda like when u have a car started and you to turn the key to start while already started... kinda like a squeal sound... come on guys try help me out with this been without a car for almost month...
steeze69
May 24, 2021 02:57 AM
BlingSlade
Nov 20, 2015 06:56 PM
Klunkerbill
Nov 9, 2015 11:39 PM
Pkdust
Oct 20, 2015 04:27 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
