new 2.5L engine in 2006 TC
Old Nov 25, 2010 | 12:52 AM
polskifacet's Avatar
Default new 2.5L engine in 2006 TC
I have a 2.5L from a Rav4 laying around and I am wondering if I could use it in my manual 06 TC since i blew the engine. You guys think its a direct swap?
Old Nov 25, 2010 | 01:10 AM
johnnyb305mia's Avatar
im pretty sure its not but do it it would be nice since u have it lol
Sent from my T-Mobile G2 using Tapatalk
Old Nov 25, 2010 | 02:08 AM
Dkfung88's Avatar
are u gonna try to fit the rav 4 ecu with ur tC harness? good luck =P
Old Nov 25, 2010 | 11:44 AM
Olesen_Custom_Automotive's Avatar
Scion Dynasty
no such thing as a "direct swap" unless its the same chassis code
Old Nov 25, 2010 | 02:26 PM
Spr4yedTc's Avatar
dont let all these guys tell you what can and cant be done, if u want to do it then get it done
itl will require a custom passenger motor mount or u can modify your stock one to fit the timing cover of the 2.5
you will need the 2.5 engine harness unless the 2.5 uses all the same sensors (would be lovely if u can use tc harness on it, kinda like we do for 1jz,2jz, 1.5jz swaps)
if u use a 2.5 harness you will need the 2.5 ecu and to modify your body harness plugs to fit the ecu and right pinouts
hopefully the trans fits the 2.5 im preatty sure with little to no modification it will and if it does then that cover the other 3 motor mounts
Spr4yedTc's Avatar
i was able to stick a 2.4 from a camry into my chassis which uses a different passenger motor mount and different oil pan
Old Nov 25, 2010 | 03:01 PM
Scion Dynasty
for the amount of money and frustration you'd put into a 2AR-FE @ 170hp, you could completely rebuild your engine with a turbo and get 300+hp
its your car, do w/e you want
Old Nov 25, 2010 | 05:09 PM
headache it will b but he has the motor there so y not give it a shot u know
Old Nov 25, 2010 | 05:35 PM
Scion Dynasty
id rather buy a race shell and throw the motor in that, why ruin a good running car? build a new one.
Old Nov 25, 2010 | 06:08 PM
if he got the money for it yeah i totally agree n have 2 beasts lol
Old Nov 25, 2010 | 07:10 PM
I know all the 2.4 2az are the same except for the timing cover. I was hoping it works with the old harness and sensors.
Old Nov 26, 2010 | 04:17 AM
BlackKnight's Avatar
Music City Scions
I agree it wont be a direct swap. I'm sure its sensors, plugs, injectors etc are all different including ECU. You would have to use the wiring from the 2.5L and ECU. A lot would be involved with this swap. I'm not even sure the motor / transmission mounts would be anywhere close to the same either.
Of course anything you want to do can be done with the right amount of money.
Old Nov 26, 2010 | 02:32 PM
Spr4yedTc's Avatar
Originally Posted by polskifacet;3729027[B
]I know all the 2.4 2az are the same except for the timing cover[/B]. I was hoping it works with the old harness and sensors.
i thought the same till i put in my camry motor with my ecu and my idle read 13 vac and idles like it is mildly cammed ... im certain the camry cams are of a different kind or the sensors are atleast
they are pretty damn close.. and as far as sensors im pretty certain they use similar sensors... they are new and proven
Old Nov 26, 2010 | 05:55 PM
Music City Scions
Even so don't assume you can use 2.4L 05-06 tC sensors in it, they could have similar outsides but have different internal resistance or read differently (meaning the signal sent back to the ECU could be different).
Old Nov 26, 2010 | 08:15 PM
Spr4yedTc's Avatar
very good point im giving it the benifit of the doubt tho id like to see someone try ya know
annika
Mar 16, 2015 06:36 PM
tom0613
Mar 7, 2015 05:59 PM
boxmobile
Mar 7, 2015 02:54 AM
Kiwibox
Dec 15, 2014 09:46 PM
