mid pipe remvoal help
i have a tusudo mid pipe that i want to install and have tried numerous times. i cant find a way to get the 2 bolts off that are near the cat. when i brought my car into Toyota to get a new clutch/ flywheel i had them take off the bolts and grease them up or whatever and i tried to get it off again but no luck..if anyone has any ideas it would be greatly appreciated.
no not at all it was pretty rusted and when i got it back from toyota it looked like they didnt even touch it. but they said the took em out and put em back in... should i take off the axel back part of it first or somthing like that?
i had the same problem....but i striped the bolt.. so i used the bolt cutter and cut the head off the bolt. then i tried those clamping pliers (what ever there called) to get a grip of the bolt and tried to twist it loose...but that didnt work also. then i just drilled out the remaining bolt. finally i used a thread-maker tool. and it all worked out....
hope this helps
hope this helps
^Agree. I had the same problem when changing my S-pipe, the header bolts were a lot easier than the mid-pipe bolts. Also, what are you using to break the bolts loose? I soaked them and used a breaker bar.
I'm in the same situation, I've tried 3 times now to get those bolts out with no luck. Tried penetrating oil, breaker bar, and impact wrench and they still won't budge. The weather here makes everything so rusty, I'm just going to cut them off next month.
if there rusted to a point where there goona give you issues when tighting back up,i would just have them cut and install new bolts,cause when i put my midpipe on,the bolts were rusted to a point where nothing would grip on it,and even if it did,it would round the bolt,so i just had my local shop cut the bolts up and while he was under there,i had them but in my new midpipe along with the supplied bolts that came with it,
so this way the next time i need to take it back out,ill be easier
well i just tried again this morning and i just said f that when the first bolt pretty much striped but im just gonna go get them cut today hopefully. and Toyota took off the header bolts and greased them not the mid pipe lol well atleast it will be easy for me to take that off when i get a turbo.........
lol i had a axle back n1 on my 2007 before i totaled it and my dad sold it faster than i could get it back but i am about to order the n1 axle back for the one i got now. and it does have a nice sound right when you start it up.
Alright another question. so i have the mid pipe on and ive been hearing some rattling and i looked at it and it is rubbing against the thing sheet of metal that is above it and the bolt thats right above the resignation. would it be a bad thing if i took that off?
SloTC1
Aug 16, 2018 02:45 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
