How low with 19's?
Old Mar 8, 2005 | 03:06 AM
littleblackbox's Avatar
Default How low with 19's?
So the weather is starting to warmer up here, and you know what that means, time to get the box ready for Spring and do alittle extreme makeover. I have 19" wheels running 215/35 tires, now my question, How low can I go without having to many issues with rubbing. I have heard a few people running Tanabe df210's which have a 2.2 drop in the front and 2 in the rear. Anyone running these have any words of wisdom for me.
Old Mar 8, 2005 | 03:13 AM
hotbox05's Avatar
You will rub no matter what, if you ran 30 series tires the rubbing wouldnt be as bad.
Old Mar 12, 2005 | 07:30 AM
subcode's Avatar
not necessary so.....check me!
Old Mar 12, 2005 | 08:22 AM
aireck's Avatar
exactly... on a 30 series you would be ok....
i am running 215/35/19's and no rubbing...
and i drive fast.. well as fast as an xb can go..lol
i do swerve a lot but it takes it...you should be ok with 19's and the tanabes with running 30 series ...might rub a lil with 35's but i'm not sure on those. but i am on the 30's..
Old Mar 13, 2005 | 09:19 AM
tinybigrig's Avatar
the front rub will be negligible depending on what offset your wheels are, but the reaer may rub and the trailing arm. the solution, in the front you may need to cut a 1x1 in square into the fender lining, and the rear can be fixed with a simple 3 or 5 mil spacer, either of which will be fine with the stock studs
brent
pm me if you have any further questions, wheels are my life, its how i pay the bills
Old Mar 13, 2005 | 11:48 AM
Dwestxb's Avatar
I'm running 19's with Goldlines (2" drop) and have no rubbing issues at all.
Old Mar 13, 2005 | 02:13 PM
joe_rogan's Avatar
I am runnig tein tech s and everyone says it is the perfect drop. Only rubs when wheel is turned all the way.
Old Mar 17, 2005 | 09:48 PM
ok well I am now runninf 30's and have df210's on the way, guess we will see
BlingSlade
Oct 19, 2016 12:39 AM
neneago
Oct 27, 2015 04:47 PM
gqdabien
Sep 17, 2015 09:23 PM
Robineileen324
Sep 14, 2015 06:21 AM
prescottn
Sep 13, 2015 09:04 PM
