Am I getting screwed?
Old Dec 8, 2010 | 06:11 PM
sciontc1207's Avatar
Unhappy Am I getting screwed?
Alright guys I think I am getting screwed.. cliff note story is clutch slipping..start car one day starts and stalls out... then will not start.. think cause of TOB and slipping clutch... have taken to transmission shop were they refer me to another shop cause they don't want to pull transmission with not starting.. well i have to taken to shop.. now they say that head has bent valves.. so they wanna charge 450 to pull head.. then take to machine shop where they say that all but one valve was bent and will cost 450 to fix.. and now they say have to replace vvt and timing chains and few other parts.then all the labor to put back together.. which now adding up to almost 3000 in parts and labor.. This really is putting me in bind and is alot of money and thats not even putting the clutch in car... does this even sound right?
Old Dec 8, 2010 | 11:08 PM
thendawg's Avatar
What all is done to your car perf mod wise?
Old Dec 8, 2010 | 11:38 PM
All modded was 2 years ago put in stage 2+ spec clutch
Old Dec 9, 2010 | 12:28 AM
thendawg's Avatar
Take the exhaust manifold off and check for yourself. If they're saying all valves are bent, when you take the exhaust manifold off it will be obvious. If thats the case, there price is def in the ballpark. You could always just swap in a junkyard motor yourself for under $1000 for the motor if you have the experience/time.
Old Dec 14, 2010 | 01:53 AM
Speck102's Avatar
They are trying to rip you a new one. You can get a used engine for around $1k and have it swapped in for another $400-500. If you are located anywhere in Norcal PM me, I can help you get things figured out.
Old Dec 15, 2010 | 04:22 AM
thendawg's Avatar
Umm $400-500 for a motor swap?? Pulling the motor is like 8 hrs on the book, and another 8 to put the new motor back in - thats 16 hrs of shop labor minimum. The going labor rate is $65-100/hr depending where youre at so youre looking at $1k minimum in labor only to pull and replace the motor and thats without shop supply fees/fluids/etc. $400-500 is good for a "mechanic friend helping you do it at your house" rate, but dont expect to pay that at a shop, to be honest, id expect to pay around $1500 total in shop labor + misc shop expenses, in addition to what you spend on the engine.
Old Dec 15, 2010 | 06:30 AM
Speck102's Avatar
Well, I don't know what kinds of shops you have around you. My "mechanic friend helping you do it at your house" price would be about $300-400 depending on the car. Paying $1,500 for a swap is ridiculous for a car like a scion. Find a shop that charges a reasonable rate for the work being done on your car. Pulling the engine should not take anyone more than 2-4 hours the TC. Just find an honest mechanic that has a smaller shop to work out of. Don't go to the dealer where you will get raped on labor charges. You should pay about $500-800 for pulling out the engine and putting in a new one on a car like that. Anything more is just robbery.
I do this sort of thing myself most of the time, so I speak from experience. I only pay a shop when I don't have them time or desire to work on one of my cars.
Old Dec 15, 2010 | 02:41 PM
ElCapitan's Avatar
just get a new motor. theres a ____ load of camry motors sitting around everywhere for 500 bucks
Old Dec 15, 2010 | 04:00 PM
thendawg's Avatar
Well "I did this sort of thing" for a living, so I know how much its supposed to cost. Its not ripping you off, its a fair rate, call around to any reputable shop and I promise youll get a number close to that. In fact $65/hr is CHEAP by todays standards - and I looked it up - Pulling and replacing the motor in an 07+ tc, swapping the transmission and other needed parts over, plus refilling fluids is 17 hrs on the book. Im not here to say you cant get it done cheaper, Im just trying to tell you that it is a fair price from a reputable mechanic's shop, and its not someone trying to rip you off, they're just trying to make an honest days living. By the time the shop pays its overhead, pays the front end employees, and pays the mechanic doing the work $15-20/hr, theres not alot left.
Old Dec 15, 2010 | 04:01 PM
thendawg's Avatar
As for motors themselves, yes you can find them very cheap - the last one I built I paid $450 for a running longblock
Old Dec 15, 2010 | 04:41 PM
TotalChaos's Avatar
Have you gotten a second opinion? That's a huge issue going from clutch slipping/tob to now bent valves etc. Were there any known issues b/f problem with clutch surfaced?
Old Dec 29, 2010 | 12:19 AM
I am bout to take to scion dealer.. They found a thrust washer in bottom of oil pan and it has mangled alot of internal gears.. Gonna see what scion says warranty wise cause its still under 60000/5 year drivetrain.. just have to get it to the dealer.. if not covered will need to supply a long block
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
StxArOne
Scion xA Aero & Exterior
Apr 3, 2018 02:22 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
StxArOne
Aug 21, 2015 06:44 PM
Jumphiggggg
Scion tC 1G ICE & Interior
Jul 15, 2015 02:29 AM
