Corrosion around MAF sensor on Short Ram Intake?
Old Dec 19, 2010 | 09:24 PM
ajcadoo's Avatar
Default Corrosion around MAF sensor on Short Ram Intake?
Does anybody know what is causing this?
It does not affect the performance of the car. And i just noticed it while under the hood today. It has also been raining a lot here in San Diego. Is this something that could do damage? How to fix it?
Old Dec 19, 2010 | 10:05 PM
Jdub86's Avatar
MN Scions
Wow that's crazy, I have never seen anything like that before. If its not affecting the performance than its probably just on the outside of the pipe.
I would take it apart and try cleaning it and to get an idea of whats going on.
Old Dec 20, 2010 | 01:05 AM
jwaj2002's Avatar
TOCC
it looks like something spilled on it honestly, do you wash your engine bay out? what year xb? how old is the battery?
Old Dec 20, 2010 | 02:10 AM
ajcadoo's Avatar
No, but my grille is the chromed aluminum slats. I do have some minor protection from the outer elements but rain can still get inside the bay. Its a 2006 (read my sig?) and the battery is literally 2 weeks old. Just replaced the original stock one.
Old Dec 20, 2010 | 02:30 AM
jwaj2002's Avatar
TOCC
what is the chance that the old one leaked and did that?
Old Dec 20, 2010 | 08:01 AM
Davestoaster's Avatar
You live in San Diego, and you have that kind of corrosion? I could guess something like that in the rust belt, but San Diego?
My guess, if it wasn't a chemical like your battery, would be some sort of galvanic corrosion caused by maybe a bad ground to the engine.
Old Dec 20, 2010 | 08:51 PM
frogbox's Avatar
That would be if the section was in contact with the electrical system , it is isolated with rubber hoses and anti vibration mounting.not even the MAF sensor makes a connection with the intake ( plastic with o-ring gasket)
I would say it is battery acid spilled on it during the replacement , and not being cleaned properly after. Try rinsing with a solution of water and baking soda , if she bubbles when you do it you will have found the cause. The fix would be to remove it , clean it with baking soda lightly scoth brite it and then clear coat it.
Old Dec 21, 2010 | 06:10 AM
ajcadoo's Avatar
Thanks frogbox! I am sure that is probably the problem. The last time I looked under the hood was when I replaced the battery. Although, I do not know how the acid could have easily spilled since I was holding it the whole time while taking it out. As long as it isn't damaging. I will clean it like you said and will update this thread to see if that was it. Does battery corrosion take a couple days to form before it is white like that?
Old Dec 21, 2010 | 03:37 PM
MadMike550's Avatar
good call on the battery acid...after looking at the pictures. there is very little else it could be
Old Dec 21, 2010 | 06:00 PM
frogbox's Avatar
If you scrape a soda can ( aluminum ) and put a couple drops of battery acid on it you can watch it bubble up and do what you intake did in a few minutes.
( your welcome just tryin to help)
Sumtallguy
Mar 24, 2015 04:55 AM
Chopper81
Mar 16, 2015 07:06 AM
Exclusive
35
Jan 27, 2004 10:53 PM
proto_k7
Dec 24, 2003 07:50 AM
kidkamel
Oct 10, 2003 06:41 PM
