tomocoloco
12-20-2010, 02:48 AM
I'm installing a remote starter on my 2006 xB and I thought it would be a good idea to check with you guys to see if any one knows if the ECU/ECM has the ability to shut the engine down if there was low oil or high engine temperature?
If it does not do it automatically I plan to wire some of the "idiot" lights on the dash to a relay to trigger the "enable" wire on the remote starter.
One simple example is the ECM has a grounded output it sends to the water temperature high indicator light on the dash. The other side of the light is constantly connected to power (so grounding it turns it on). I plan to wire the one side of a cube relay to constant power and the other side of the coil to the grounded output from the ECM that turns on the water temperature high indicator light on the dash. Basically the relay coil will be in parallel with "idiot" light. Then I will use the normally open or closed contact of the replay to make or break the remote start "enable" wire.
This way if the warning light(s) on the dash comes on while no one is in the car to see it and react to it. The remote start will be turned off and the engine will (hopefully) be safe.
I was wondering if there was anything I could use to stop the engine if there was low oil pressure, I did not see anything in the factory wiring diagram.
Don't worry, if I do have multiply "idiot" light wired to the remote start I plan to use one relay for each "idiot" light I parallel wire into, to keep all the circuits isolated. All the relay contacts (switches) will be wired in series (AND Logic) so if any one of them is activated it will shut the remote start down.
I've installed alarms and remotes starts before, but this is the first time I considered this. I surprised that the manufactures of these systems don't recommend to do something like this.
Any input is welcome, especially any other cool ideas of this I can input or output to the remote starter.
Thanks.
Thanks.
