RCA to aux cable?
Old 01-07-2011, 02:23 AM
monty's Avatar
Default RCA to aux cable?
I want to replace the radio with a Pioneer avh-3200bt but I don't want to have an aux cable hanging from the front of the radio. Can you use an rca to aux cable in the audio input on the head unit to get sound from an mp3 player...not ipod? Also, what is the best install trim kit for a near factory look?
monty is offline
Old 01-07-2011, 06:00 AM
Utah Scions
xseveredveganx's Avatar
If the headunit has the aux in option, I don't see why you couldn't. Also, you may be able to tap into the OEM aux port through the console. Just have to figure out all the wiring.
As far as the trim, I've used Metra with a decent look. If you want it to look seamless, I'd recommend gluing the trim pieces in, body work, and paint.
xseveredveganx is offline
Old 01-07-2011, 08:59 AM
monty's Avatar
The head unit has a front aux port and rear audio/video inputs. The manual didn't go into detail about audio in.
monty is offline
Old 01-07-2011, 02:45 PM
oreoremix42's Avatar
Does yours have a usb port? It should I have the dble din model and it has a usb cable.
oreoremix42 is offline
Old 01-08-2011, 12:28 AM
monty's Avatar
The AVH has a front usb. I was finally able to contact Pioneer. They said I could use the adapter cable, but the display would be blank.
monty is offline
Old 01-08-2011, 10:00 AM
KaneoheKoa's Avatar
Yeah, since the audio in is only audio, no data. Just make sure you get a mount for your MP3 player to make it easy to use. Also, many of the trim kits work well in the xB. Personally, I wouldn't glue/bodywork/paint the aftermarket trims in; if you needed to remove your HU, then the trim would have to be forced off.
KaneoheKoa is offline
prescottn
Scion tC 2G ICE & Interior
04-26-2016 01:14 AM
prescottn
10-08-2015 05:31 PM
Geedavell
Scion xD ICE & Interior
09-28-2015 01:33 AM
Spitfire23
Scion tC 1G ICE & Interior
09-08-2015 03:31 AM
RokGoblin
08-11-2015 05:24 PM
Quick Reply: RCA to aux cable?
