Mr coilovers lowering measurements
^That IDK.
The best way to get things even at each corner is measuring from the center of the wheel straight up to the fender. Getting this done first try and calling it good is wishful thinking. You'll be setting the car on the ground and raising it up a few times to get it adjusted right. Do the measurement I mentioned before tearing the suspension out and you'll have a better gauge on how much you lower the car.
The rear fender line is lower at the rear for most cars, I don't know reasons of that you'll have to get at the car designers lol. The instructions should have an intial start point of setting the coilovers, I'd recimmend starting there. If you do the measurement like I mentioned before the car will sit like you want. When all is said and done it's likely none of the thread counts will be the same. Set the fronts at an even count, rears at an even count, install, get the car on the ground, measure, raise car, adjust collars, lower car, measure again. If it still not how you want, raise up car and adjust the collars again.
As a first time coilover owner I can say the overall performance is supreme compared to oem.. I have my damper set at 9 of 32. But want stiffer.. So 7 it is. However the springs are a bit, uhm springy?
I'd get an alignment done ASAP if you say the car is "pulling good to the right". No need for unnecessary tire wear, and with Firestone offering lifetime alignments you can go back in two weeks and get the alignment checked and adjusted if needed. Regarding the "springy" ride, how is the preload set? That affects the ride also.
Oh god.. The guy I spoke with on the phone about my purchase said I can take them right out the box and install.. Does that mean they're already preloaded??? Wtf.. Can I adj them while on the car?
^You sure can adjust while they're on the car. Just make the measurement as mentioned on the link, if they're the same left to right then you should be good. If you want to go all out an loosen the top two perches and do the preload yourself that's cool too. It's always good to double check and make sure things are set right, it's just easier to do before anything is installed on the car.
