2004-2006.5 [NCP61]
CEL
Old Jan 16, 2011 | 10:35 PM
xamike's Avatar
Default CEL
Hello all, I disconnected one of the injector wire harness connectors today to clean some spilled oil behind the injector rail. I forgot to plug it back in and started car. After it started running a little rough I realized I forgot to put it back in, however the check engine light came on. Do you know if it has to be reset or will it go off by itself? Thanks.
Old Jan 16, 2011 | 11:13 PM
N0AuTHoRiTy's Avatar
You can either get a OBD reader to reset the CEL or you can run through a few drive cycles and it will turn off by itself if the ECU detects there is nothing wrong.
Old Jan 17, 2011 | 08:22 AM
RedneckwithanxB's Avatar
disconnect the ground on the battery for 10 minutes
Old Jan 17, 2011 | 12:56 PM
jct's Avatar
jct
i did the same thing with my MAF sensor once... but that one just won't make my car start
Old Jan 17, 2011 | 08:28 PM
xamike's Avatar
Default ty
Ok, thanks guys, it went off by itself, after like 10 minutes of driving, turned car off, turned it back on, and light went off.
Old Feb 9, 2011 | 09:13 AM
smithsen1's Avatar
you can just live it as such. no problem
whooty
Apr 19, 2023 05:34 PM
MeDizzy
Oct 8, 2015 03:31 PM
BigIrish
May 18, 2015 12:04 AM
xb4lf
Apr 4, 2015 07:15 PM
D_Roke
Mar 31, 2015 05:37 PM
