the dreaded vsc/trac off/check engine light.
Old Jan 23, 2011 | 12:26 AM
kurt72's Avatar
Default the dreaded vsc/trac off/check engine light.
hi, total NEWB here. have had my 04' Scion since i bought it new in Dec 03. great car never had a problem with it. do routine maintenance and it runs like a charm. it's got approx. 122K miles on it.
i have found several threads pertaining to the vsc/trac off/check engine light. but none where it has come on right after an oil change. prior to the oil change, i did a motor flush. looking online, it's sort of hit or miss on the engine flush. whether it's good or bad. but the brand i used, i couldn't really find anything that said it screwed up a motor. i noticed there was a little bit of sludge and that's why i did it.
keep in mind all of this was done by myself. i've be sort of 50/50 when it comes to oil changes. sometimes i take it in, sometimes DIY.
after the oil cap was put on, i started the car up. cool, then the engine started to knock a little bit, then subsided. then the check engine light vsc/trac light came on. shut id down immediately. let it sit for a few minutes. started it back up again. runs fine. took it around the block. great acceleration, still plenty of pep, no more knocking.
i am thinking that the flush dislodged some of the sludge. and some still remained even after i drained the oil, making it run funny. now the sludge may be broken down? and the sludge screwed up a sensor, giving me the check engine light?
after cooling down for a couple of hours, i went back outside and started it up again. seems fine. regardless, im going to take it in to have it looked at, check the warning lights. im am hoping i did not TOTALLY HOSE the motor.
Old Jan 23, 2011 | 06:35 PM
ajcadoo's Avatar
Yeah, those lights come on for ANY problem throughout the car. I would definitely take it in and run it for the CEL codes and see what comes up. At least the car isnt totally pooping out on ya.
Old Jan 24, 2011 | 02:38 AM
kurt72's Avatar
thanks. i HAD to drive it today. no problems. a little knocking while it was warming up. takin it in tomorrow.
Miqmiqmiq
Apr 16, 2016 02:34 AM
csmonte
Jun 26, 2015 08:44 PM
Maarifa
Mar 13, 2015 04:07 AM
XDC
Feb 1, 2015 11:56 PM
eatcrispycreme2
Jan 30, 2015 03:43 AM
