View Full Version : trouble with emanage
mijos87
01-30-2011, 01:07 PM
well ive done the greddy 06 rewire accorrding to the diagram on SL .... un fortunatley the ecu end of the connector is not getting the singnal for the number four injector all the way across...... in other words
pig tail(d connector for D1 red n purple wire) has positive continuity
molded side no continuity( traced the spliced wire and nothing....)
because of this my number four injector wont fire up, completely dead. i checked by plugging it in without the emangage and it fires up fine code goes away, all 4 get gas, signal, spark ect.... anyways how would you fix that side is it possible?:nails:
RedneckwithanxB
01-30-2011, 02:07 PM
Are you getting anything out of the emanage for that injector? If yes, then it might just be a weak connection in the splice, if no, then you may have a fault in the harness for the emanage...
Use a multimeter and see if your getting any kind of signal from the emanage on the wire, then move to the pin on the harness where it plugs into the emanage...
mijos87
01-30-2011, 02:14 PM
out the emanage is fine, i put the ground on the red and purple wire on the a harness to the emanage then on the splice i made im good there.... i then put the ground on the splice and then on the pin going to the ecu (not the pigtail side) and i get a 1.932 no continuity beep nothing...
