tachometer
Old Feb 7, 2011 | 04:26 AM
mudvayne2k6's Avatar
Unique Scionikz
Default tachometer
hello has any one tried to install an aftermarket tachometer on the xb2? i wanna install one a monster tach with a shift lift. i have installed one on others olders car but not on the newer models. Should i just tap into the wires in the back of the gauge cluster? or should be tapped into the computer? any help would be appreciated. thanks in advance
Old Feb 7, 2011 | 01:19 PM
my06tc's Avatar
just get a shift light
Old Feb 7, 2011 | 06:35 PM
AAG's Avatar
AAG
DeepSouth Scions
Don't do it. Not only do you NOT need it, it's ugly and pure rice. Now if had a drag setup, then I'd see your reasoning behind it.
Old Feb 7, 2011 | 10:34 PM
Greg S's Avatar
It would probably be easier to tap the tach line behind the cluster since the ECU is under the hood. Don't know which wire it is though so you'll have to test.
Old Feb 7, 2011 | 10:51 PM
draxcaliber's Avatar
the car already has a tach, why do you need a second one?
Old Feb 20, 2011 | 05:29 AM
RedDragons's Avatar
dont rice your B up. just get a shift light like said before.
according to directechs...
tachometer | grey | ac | located @ datalink connector, white 16 pin plug, pin 9
you should be able to find the wire on the back of your gauges as well
messyjesse87
13
Oct 16, 2011 06:48 AM
athlete3232
10
Apr 21, 2009 12:03 AM
montague
Scion xD Drivetrain & Power
10
Dec 7, 2008 03:05 AM
jiggadomino
Scion tC 1G ICE & Interior
14
Nov 7, 2008 07:55 AM
aznchild
Oct 12, 2006 06:01 PM
