Pics of painted calipers on TCM?
Does anyone have pics of their painted calipers/drums on a TCM? I want to do this soon and cannot decide which color. I am down to Blue, Red, Yellow, and Silver.
Thanks in advance.
Thanks in advance.
Red is traditional and will pretty much suit any car where
you can see the calipers. I'm considering yellow to match
my GoldLine springs and future Koni Yellows...but I'm not
painting my calipers till I do a disc brake conversion for
the rear.
the rear.
I am pretty well decided on blue, as long as I can fine the right shade. I think it will hide dirt well enough and will still stand out. I will do this within the next couple weeks.
I was thinking about trying this, gonna look some more. http://www.tirerack.com/brakes/g2/caliper_paint.jsp
The G2 kit is good, I used the Duplicolor kit, it's good too. Uses a ceramic additive to withstand heat. Got it at Walmart for about $15. I did yellow to match my springs. Mine don't seem to get much brake dust, but then, I don't brake much and my wheels don't build up hardly any dust with the openness to them.
Here's a TCM in Red:
Mine in yellow:
Mine in yellow:
I painted mine at night and let it sit in the garage over night before I put the wheels back on. Probably a little longer than needed but wanted to be sure. It pretty much dried in a couple hours...
He probably used jack stands which his the smart way to do it.
I used the caliper paint from Autozone. The caliper paint is not only hi-temp paint it is also chemical resistant. Brake cleaner is brutal to painted surfaces.
Before you paint make sure you calipers are very, very clean and use more than one coat but allow adequate drying time between applications. Take your time and make sure everything is clean.
