2AR-FE motor swap in with 6 speed auto
Old Feb 17, 2011 | 05:35 AM
r2d2michael's Avatar
Smile 2AR-FE motor swap in with 6 speed auto
the tranny..
so i know for a fact that the new 6 speed auto ( U70E ) WILL bolt to a 2AZ-FE ( 2.4L ) and the older 4 speed, the one we have, (U241E ) WILL bolt to the new 2AR-FE (2.5L) and 1AR-FE ( 2.7L ). what i dont know is how close are the motor mounts and being that its an auto do i need a new ecu.
i would think i would need the ecu because the ecu tells the tranny when and what gear to shift to. so if my tranny has 2 more gears than it did before, how will the old ecu know that and tell it to shift into 5th ot 6th? also would my dash say 5th or 6th gear in sport mode or stay at 4th for 4th 5th and 6th gear?
here are the gear ratios for the 2 trannys just to have.
U760E
first (3.300)
second (1.900)
third (1.420)
fourth (1.000)
fifth (0.713)
sixth (0.60
U241E
first (3.943)
second (2.197)
third (1.413)
fourth (1.020)
im looking at the newer tranny beacuase for the 2 extra gears. i would love to ride on the high way at 70mph and below 3k lol
the motor...
i want to find a trashed tc2 and snab it motor. after looking at some dynos for boosted 2AR-FE ans 2AZ-FE im seeinf about 50-60 hp jump. not sure what the the 1AR-FE would be boosted? so if the motor mounts are close( i can weld damn near anythng) i would need a new wireing harness, ecu, motor mounts, and what else?
if anyone know someone with the tc2 or the newer camray that could measer the block to see if i could keep my header and s-pipe that would be great lol. just wounder how close it is.
i have gone over just about every toyota engine and tranny and it really seems the best way would be the 2.5l or the 2.7l and the U760E tranny. if anyoone has ANY INPUT and real info please post!!!
Old Feb 21, 2011 | 08:03 PM
so after talking to rob at DESCENDANT the new 2ar-fe is completly diferant from the 2az-fe. nothing is the same. so i will probly do the 6-speed auto swap first. they are working on swap kit for the tc1 and xb2!!
Old Feb 21, 2011 | 08:23 PM
Kingshawty12's Avatar
i was wondering how much longer it would be for someone to do or even think about swapping to the new motor. xD
Old Feb 21, 2011 | 11:46 PM
TrevorS's Avatar
Too bad, so much for my daydream about swapping in a used 2AR-FE !
Old Feb 22, 2011 | 06:12 AM
im sure it will be done. just not my me lol. ill do the tranny swap for sure!!
Old Feb 28, 2011 | 07:50 PM
Roller_Toaster's Avatar
I wouldnt mind not having a 4 speed anymore. Highway driving sucks.
Old Mar 11, 2011 | 02:49 AM
oreoremix42's Avatar
What about 6 speed manual?
Old Mar 11, 2011 | 02:51 PM
descendant is working on kit for the manual too.
Old Mar 19, 2011 | 07:23 PM
Kiddtango717's Avatar
6 speed would be amazing!!!! but i wouldnt even mind just a 5 speed at the moment. when im in sports shifting mode it's like 2...3...4....... ...... ..... DAMMIT FUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU~!!!!!!!!!!!!!!!
Old Mar 19, 2011 | 08:53 PM
^^^i feel your pain lol^^^
Old Mar 20, 2011 | 03:54 PM
DJ_FroZone's Avatar
if the six speed auto is possible i may wet myself
Old Mar 20, 2011 | 09:42 PM
TrevorS's Avatar
I've been having that problem with my Eclipse for years. I get all set to shift up, push in the clutch pedal, and then realize I'm already there -- fifth! I've just started getting a little of that with the xB2 as well, but nowhere near as bad !
Old Mar 20, 2011 | 11:24 PM
I would love to drop a 6speed manual in my car and get rid of the 5 speed. I want better mpg!!!!
Old Mar 20, 2011 | 11:28 PM
^ dibs on your 5 speed tranny if you swap in a 6 speed. :D
Old Mar 20, 2011 | 11:57 PM
TrevorS's Avatar
Yes, a true overdrive would be nice. It's not as though the engine lacks the power to support it. I see those posted gear ratios include two genuine overdrives -- nice !
Old Mar 21, 2011 | 05:35 AM
CIONIDE's Avatar
Your 5-speed manual has overdrive ratios also, but the axle ratio is so high that it is basically negated. From another thread:
Originally Posted by CIONIDE
5-speed manual gear ratios:
1 = 3.54
2 = 2.05
3 = 1.33
4 = 0.97
5 = 0.73
reverse = 3.58
axle ratio = 4.24
4-speed auto gear ratios:
1 = 3.94
2 = 2.20
3 = 1.41
4 = 1.02
reverse = 3.15
axle ratio = 2.74
Old Mar 21, 2011 | 04:53 PM
TrevorS's Avatar
Urgh -- done in by the axle ratio !
Old Mar 22, 2011 | 08:41 PM
streetxdreamer's Avatar
6 speed auto would be nice
Old May 11, 2011 | 09:00 PM
cTek's Avatar
any word on the 5speed manual to 6speed manual swap for the xb2 yet?
Old Jan 26, 2012 | 01:45 PM
clifsmith's Avatar
After my warranty period is up, if there is anything I want to do more on my 2011 box, it is to swap out this 4spd auto (U241E) for a 6spd auto (U760E). Stock 4spd, turns way too many RPMs on the highway in comparison to the vehicles of today. Shift smoothness and much better fuel economy should result. I emailed Descendant and they did not know anything about a auto trans (4spd to 6spd) "swap Kit" for the xb2. I want to keep the 2.4 engine and just want to swap tranny. I realize the ECU change would be required since there are 2 extra gears, but this ECU would have to be from a car with the 2.5 since the U760E was never built for the 2.4. So if the 2.5 is a completely different engine than the 2.4, then how can this new ECU work with the 2.4 and U760E combo? Any ideas how this will work out?
Any other alternatives (like axle gear swap to taller gear) for me to get better highway mileage?
