View Full Version : FLUSH BODY/RIMS LOOK
theorientonline
02-08-2004, 04:45 PM
what size rims for 18" and tires do you all suggest for a FLUSH look?
hahajoey
02-08-2004, 05:02 PM
18x8 +30 should be near ok.
u can run that setup just fine,
no rubbing or anything. i suggest going multipiece
since with a 8" width that rim would be heavy
unless its a hi quality rim..
IE: te37, le37, se37k, those are nice 1 piece's..
and u can rock gt-n.. i HEARD they make them in +31
offset but 18x7.5(which is still siiick)
LVXB
02-08-2004, 05:21 PM
low offset is what you want to go for the "flush" look. i have +25 offset and my fronts are flush. the backs could use just little bit more (+5 mm) to be perfect. but i am happy anyways.
user beskone has some staggered offset axis 7mods that are 18inch and flush and sweeett. check his profile or his posts.
Besk_one
02-08-2004, 05:31 PM
thanks man! :)
ya i have 18x7.5" +42 front and +35 rear, and the rears *still* aren't even with the front! i was thinking about running a 5mm spacer in the back and i think that will probably even them out really close i think it's about a 10-15mm difference between front and rear , just gotta get around to picking up the spacers and seeing how they work.
LVXB
02-08-2004, 05:36 PM
were you there at el toro man? i didnt see your car...aggh not enough time/attention span to spend.
theorientonline
02-08-2004, 05:51 PM
if you all can...post your pics...
Besk_one
02-08-2004, 06:22 PM
no i wasn't at el toro (i had a wedding to attend), but spfr jon drove my car out, so it was there :)
here's the link to some pictures
http://homepage.mac.com/besk_one
look for the Axis Mod7 gallerys :)
brian
theorientonline
02-13-2004, 02:48 PM
anyone have the flush look on their ride?
cowboy
02-14-2004, 08:33 AM
yep, but their 16x7's:
http://www.scionlife.com/forums/viewtopic.php?t=6985
theorientonline
02-16-2004, 10:32 PM
what do you all recommend for a 17"x7.5" 41 offset rims with what size tire (215/40/17 or 215/45/17) and springs(espiler/eibach -1.6/-1.8 or tanabe -2.0/-2.2)?
Kendo
02-21-2004, 12:51 AM
I'd run the 215/40R17 tires. This is closest to factory tire height. I'm sure either set of springs will be fine. I have the Eibachs and I have plenty of clearance still with no rubbing issues. The extra 0.4" shouldn't rub either as there is plenty of room. The only thing about 17×7.5 ET41 wheels is that they will look tucked under.
