View Full Version : Forjworks 2011 Scion XB Air ride systems front struts.
eight08customs
02-18-2011, 04:50 AM
http://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc6/185933_200338776645176_100000071656817_750070_4568425_n.jpg
Side Skirts are just barely scraping the ground
Marshalls Gen 2 XB "First Gen 2 XB on Bags" with its new look and newly designed prototype struts.
Order online
Forjworks Air Ride Systems Gen 2 2008 and up Scion XB kits are now for sale one out site.. You can just click and order directly online!
http://www.forjworks.com/Product.aspx?ProductId=84&CategoryId=40#
Ok guys we finally at www.forjworks.com designed our AIR STRUTS SYSTEM for the gen 2 Scion XB that is just as low or even lower than any kit that is out on the market. It will be ready for retail soon.
With months of R&D work on these struts this kit will get you LOW! our bag perch placement gives you optimized lowest possible drop as well as a smooth ride. CNC Machined mounts for exact fitment that is not loose, so this eleminates rattles. Our upper plates that mount at the top of the bags have recessed holes and uses tappered bolts so the strut brearing is as low as possible.
It is designed as two types of kits.
1. DIY kit. It comes with all the mounts and bags. Our Mounts are made to fit the strut body and shafts. You will use your OEM strut with slight modification "cutting of the spring perch" and welding of the FORJWORKS AIR SYSTEM Mount to the sway bar mount, so there is no need to worry about welding onto the body of the strut housing.
2. Bolt on strut set up
All of our kits use Universal Air AERO SPORT STRUT BAGS.
All mounts are CNC machined for precise fitment
This set up will work with 19 inch wheels!
http://img.photobucket.com/albums/v649/eight08customs/Hella%20Flush%202011/DSC06408.jpg
When you need slam www.forjworks.com has what your looking for.
http://a8.sphotos.ak.fbcdn.net/hphotos-ak-snc6/182937_110859185658549_103795196364948_82390_4022626_n.jpg
Our top mounts are designed with counter sunk bolts to give you optimized bearing clearance.
http://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash1/182287_110858872325247_103795196364948_82374_3801315_n.jpg
Notice other kits the perch mount is made to be universal. notice how big the center hole is.
http://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc6/182704_110858945658573_103795196364948_82378_542128_n.jpg
Forjworks Air Systems Mounts are CNC Machined to extact fitment
nava89
02-18-2011, 04:25 PM
how much for that set up
eight08customs
02-25-2011, 02:18 AM
here is the pricing on our full kits.. our kits are the lowest in the market for the 2nd gen XB.
DIY Kits using our state of the art CNC cut strut brackets. Use you exisiting Struts.
Forjworks Air Systems Front bag Bracket
Forjworks Air Systems Rear bag Bracket
2 UAS AERO SPORT strut bags
2 UAS AIr house 2 bags
VIAIR 380 COmpressor
4 Gal Aluminum Tank
Water Trap
2 Air Switches
80 amp heavy duty Soleniod
Pressure Switch 200 psi
Line Fitting Wire kit.
1479.00
Optional but required Dakota Digital Gauges but highly required
$359.95
Optional Basic install "Hawaii only"
$1000.00
Plus shipping
bolt on Kits using our state of the art CNC cut strut brackets mounted on Tokico Blues or KYB depending on application
Tokico Blue struts (FR) and shocks (RR)
4 Gal Aluminum Tank
Water Trap
2 Air Switches
1859.00
$359.95
$1000.00
Plus shipping
NOTE: WE do not use push to connect fittings like all the other kits in the market. We work in this industry so long and deal with tons of fittings on a daily baisis and push to connect is a fitting that doesnt last becuase of rubber O Rings inside of them used to seal. As we all know rubber get hard and birttle and starts to leak. All of our kits come with DOT Compression type fittings that are by far the best in the industry and will last.
Here is an cut away of a push to connect fitting.
http://a6.sphotos.ak.fbcdn.net/hphotos-ak-snc4/163482_1803063634544_1178444336_2079568_8285133_n.jpg
eight08customs
02-26-2011, 08:42 AM
WE only use CNC to cut all of our brackets. So everything is precise!
IF you have any questions please Email info@forjworks.com or call text 808 7532938 and our customer serivce staff will get back with you fast!
http://a8.sphotos.ak.fbcdn.net/hphotos-ak-snc3/17067_1362714626094_1178444336_1057383_7894002_n.jpg
http://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc4/150530_1729486795169_1178444336_1913008_5522039_n.jpg
Sample of what we do.
pOrk
02-26-2011, 07:52 PM
Marshall, that doesn't appear to be a DOT approved PTC fitting. Is that a Parker industrial PTC fitting by chance?
eight08customs
02-27-2011, 12:20 AM
it was a DOT fitting that was on an truck air brake system. the sleave in the center feel out when i cut the fitting
eight08customs
03-08-2011, 02:09 AM
http://www.scionlife.com/forums/showthread.php?t=200245
streetxdreamer
03-08-2011, 07:06 PM
do want
need sponsorship lol
fuqua
03-10-2011, 03:21 AM
I luv it. Let me know when you are flying over the pond for a stop in Seattle to do an install.
jrincon17
03-10-2011, 09:23 PM
seen this on fb the other night and about wet myself . love that xb !
eight08customs
03-23-2011, 03:22 AM
A kit just got sent out! Let see who pops up with it!
eight08customs
04-07-2011, 05:25 AM
Order online!
pOrk
04-09-2011, 01:55 AM
Just wanted to point out that DOT PTC ( Push to Connect ) fittings are JUST as reliable as compression. Compression fittings use plastic ferrals that are no stronger then the rubber orings inside the PTC fittings. This is all purely personal preference.
Hydraulics also use rubber o rings, and I have a press at work that will do 350 tons of pressure that uses rubber o rings to sell the rams. Just some FYI.
Do you sell just the brackets for the struts, or just a pair of struts? I've asked this a few times now without a response?
eight08customs
04-09-2011, 06:09 AM
Not going to argue the point and debate and waste my time on compression and PTC.. I know there are fans of those so be it.. we use only the best fittings compression.
So what you are saying that rubber dont wear out.. Hdy press uses special oring seals to seal that amount of pressure.. im usre its not just an oring. becuase i have repaired those cyl before
Pork sorry the only thing you asked here is if that cut away fitting was a DOT fitting.
The brackets are up on the site.
http://www.forjworks.com/Air-Strut-Bag-Brackets-Front-Set-P124.aspx
eight08customs
05-25-2011, 07:23 AM
you can purchase complete kits at
eight08customs
07-11-2011, 04:30 PM
We also sell AirREX now...
http://www.facebook.com/AirRexAirSuspension
