VSC and Trac Off lights only
Old Mar 3, 2011 | 02:25 AM
daneisthegreatest's Avatar
Default VSC and Trac Off lights only
I was throwing the vsc trac off and check engine lights. Come to find out it was my o2 sensor, the black wire was broken.
I got under there and reconnected it and poof, the check engine light went off, I reset the ECU hoping everything was good but when I started it back up, only the VSC and Trac Off lights stayed on. No other lights are displayed. I am drawing a blank on this.
I searched and couldn't really find anything on this. Does anybody know what it could be when only these 2 lights are displayed?
Sent from my iPhone 4 using Tapatalk
Old Mar 3, 2011 | 03:58 AM
ajcadoo's Avatar
My recent VSC and TRAC Only lights: https://www.scionlife.com/forums/sho...d.php?t=197935
Old Mar 5, 2011 | 12:37 AM
I'm still drawing a blank on this, ran a diagnostic and nothing came up. I don't have any wiring issues that I know of.
The car is running better than it ever has. This is blowing my mind lol.
Old Mar 5, 2011 | 02:44 AM
ajcadoo's Avatar
Yes, trac off and vsc only lights do not throw any codes. codes are only given for CELs. vsc and trac off light only should be limited to the brake system. Check all your brake lines. Thats what I learned during my research.
Old Mar 5, 2011 | 03:18 AM
Reactor's Avatar
Yes, they do. But generic code readers do not display ABS, TRAC, VSC and SRS codes. Use this thread on ClubxB to read the codes by using a paperclip and counting light flashes: http://www.clubxb.com/forums/f28/hel...c-30793-3.html
Old Mar 5, 2011 | 03:47 AM
ajcadoo's Avatar
oh nice find reactor, man reactor beasts it up on these forums. he is the definition of a xb beast.
Old Mar 16, 2011 | 05:02 AM
666box666's Avatar
i recently had the check engine lights and the vsc and trac off light on. it is a retarded vvti cam gear problem. Toyota had a service bulletin for it and if you out of your warranty they wont cover it, but I would complain. I was 1200 miles and 4 months out of warranty...had this same problem and it sure enough was codde p00 something...but its a common problem with pre 06 scion xb. hope this helps.
Old Mar 16, 2011 | 05:04 AM
666box666's Avatar
oh yeah, I complained and they did halves with me on the cost at my local toyota dealership. it was a bit of a hassle but I guess it was worth it. Not really...but I still love the box. unfortunately the problem wasnt recalled...but it had a service bulletin on toyotas website or something. found the info some where. I would get a code reader...that way you can look it up yourself but it sounds like the problem i had cause I had a break job done by a good mechanic locally...so it wasnt the brake lines or anything. it was the vvti cam gear.
Old Mar 20, 2011 | 06:20 PM
LowerLevelMan's Avatar
Good to know for future referance..............
hahajoey
Jan 29, 2023 09:51 PM
daniinpitt
Apr 4, 2015 08:07 PM
TCnewguy
Scion tC 2G ICE & Interior
11
Feb 22, 2015 04:18 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
