Need help car idiling rough!!
Old Mar 12, 2011 | 11:09 PM
osman's Avatar
Default Need help please!!!
I just chcecked my spark plugs because my car has 85k on it. I pull one out it was in OK condition i put the plug back in and I go to start my car it starts but then its idles at 500rpm or lower. I go drive it try ti floor it and it just bogs down. any ideas?!?!? oh yea and its a 06 tc
Old Mar 12, 2011 | 11:25 PM
osman's Avatar
Default Need help car idiling rough!!
I went to go check my spark plugs because my car has 85k. The plug was in OK condition still can be used. I put it back in i go to start my car and it idles rough at 500rpm or lower. I go to drive and i floor it and it bogs down it almost wants to shut off after I floor it. Idk what to do i did everything right. ANy suggestions???
Old Mar 13, 2011 | 12:57 AM
Buckets's Avatar
try resetting the computer, remove the negative battery lead for like ten mins. you gotta reset your sunroof and auto up/down windows after reconnecting the lead.
Old Mar 13, 2011 | 01:30 AM
osman's Avatar
I just changed all of them with NGK Laser iridiums. the car seemed to idle fine but when i try to rev it it bogs down. As of now i have the terminal off.
Old Mar 13, 2011 | 01:42 AM
osman's Avatar
i just put the terminal back and its still idling pretty rough =/ hmm
Old Mar 13, 2011 | 03:03 AM
Spicy_McHaggiz's Avatar
Why did you only pull one plug then start it? Did you mess with the gap on the plug at all? Did you make sure the "coil on plug" pack was completely seated onto the spark plug?
Old Mar 13, 2011 | 03:08 AM
osman's Avatar
Just to make sure I put everything back on right ive never dealt with coils only with actual spark plug wires.
Old Mar 13, 2011 | 03:11 AM
No need to make a thread here and in the lounge. Only one thread is needed.
Old Mar 13, 2011 | 04:42 AM
tribebox06's Avatar
try using some sea foam in the motor and gas tank worked for me might just be build up in the motor from bad gas
Old Mar 13, 2011 | 04:43 AM
tribebox06's Avatar
clean the mas air flow sensor to
Old Mar 13, 2011 | 09:03 AM
jbae1221's Avatar
do you have a check engine light on?
Old Mar 13, 2011 | 01:36 PM
highvoltage1's Avatar
You alreadyhave a thread for this. you dont need two!
Old Mar 13, 2011 | 05:41 PM
osman's Avatar
YEa the check engine is on.
Old Mar 13, 2011 | 06:31 PM
CSOCSO's Avatar
Get your CEL checked
Clean your MAF sensor * go to store get MAF sensor cleaner
Do you have Cold Air Intake? is your intake's small tube is closed and the engine have a small breather on the side? If yes then throw all that out and connect them back together with a hose
Do a Seafoam treatment
i did all these and my idle got much better!
especially when the AC is on... oh god my car use to shake like crazy on idle
Old Mar 13, 2011 | 07:18 PM
osman's Avatar
do the spark plugs come pre gapped because people are telling me to check my gap but at autozone they told me they are pre gapped.
Old Mar 13, 2011 | 08:17 PM
pre gapped or not, you should always check them. The gapping tool is only $1. Don't listen to auto zone about car specific issues. Get the code checked and report back.
Old Mar 15, 2011 | 12:52 AM
osman's Avatar
OK. I scanned the check engine light. It gave me 10 different codes. MAF and VAF, It said that all the coils are malfunctioned. I clicked the erase option and it deleted all the codes but the MAF. The coil codes never came back. I went and bought MAF cleaner and its still doing the same thing. Any other tips or suggestions????
Old Mar 20, 2011 | 07:18 AM
XPRESSCION's Avatar
I'm having the same problem!
I posted it on clubsciontc and couple of those guys are saying its my Torque Converter.
Has it stalled before? Mine did about 7 times within the past few months. Once the car is driven least 20 minutes; the idling is gone and is running like a champ!
cid_mcdp
Jan 5, 2015 02:45 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
ganyon
Dec 9, 2014 07:40 PM
gularti
Dec 4, 2014 01:21 PM
tC_Normo
Oct 22, 2003 07:20 PM
