Installing dme front/rear strut bars
Old Mar 16, 2011 | 11:54 AM
jblaze4lif's Avatar
Default Installing dme front/rear strut bars
Do I have to jack the car up a bit to "preload" the chasis when installing the strut bars.
I also have Trd spring/shock/sway and figured I'd try the 2 dme strut bars got them so cheap 100 for both.
Old Mar 16, 2011 | 03:54 PM
jeremydoc's Avatar
no. just remove the bolts where the strut is held up by the strut tower thing. slip the strur bar in, then put the bolts back in.
Old Mar 16, 2011 | 04:14 PM
Spicy_McHaggiz's Avatar
You should always preload your strut bars to get proper performance and prevent pops and binding. Failing to preload can cause a lot of unnecessary pops and sounds from the suspension.
Old Mar 16, 2011 | 08:38 PM
DTRUONG_112's Avatar
I installed mine without preload. I originally had the Greddy front and rear combo and now have the DME set. I installed both versions, preloaded and not and notice zero difference.
Old Mar 17, 2011 | 10:45 AM
jblaze4lif's Avatar
Damn a couple diff responses. How u like the dme front/rear combo?
Old Mar 17, 2011 | 05:24 PM
xdejablu3x's Avatar
These are not adjustable strut bars. Only adjustable strut bars are required to be installed preloaded as I were told. Strut bars like those are like the Tanabe ones. Other than that just make sure the car is straight and on a flat surface.
Old Mar 18, 2011 | 03:05 AM
Wow, I just realized that the OP said STRUT bars, I was reading sway bars. So to clarify, NO, you do not need to do anything for strut bars when you install them. For sway bars you do need to preload. (Strut bars are pretty useless in the tC anyways)
Old Mar 18, 2011 | 11:28 AM
jblaze4lif's Avatar
Thanks guys. I don't expect much but for 100 for both I'll give it a shot. Already have the Trd trio shock spring sway
Old Mar 19, 2011 | 04:59 AM
xdejablu3x's Avatar
It'll make a small difference but your talking like a 10%-15% improvement. Only thing I noticed is that the front of the car doesn't pop as much coming out of my steep driveway and during "slow to moderate" speed turns the car is flat.
killahXB2
Mar 27, 2015 10:45 AM
xa007xa
Feb 22, 2015 02:56 PM
AxRxP
Jan 25, 2015 08:40 PM
kleecker
Jan 9, 2015 02:26 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
